Metal Gear Solid: The Phantom Pain system requirements released
Metal Gear Solid V's Launch Date moved forward on PC
Metal Gear Solid: The Phantom Pain's system requirements have just been released, placing a 4th gen Intel i5 as the minimum CPU requirement. Should we be worried?
All in all when compared to Metal Gear Solid V: Ground Zeroes PC requirements, The Phantom Pain is not significantly higher, with GPU requirements being exactly the same and the CPU requirements being lightly bumped up from an Sandybridge i5 to a Haswell based 4th generation i5. Hopefully this means that this game will be an equally good PC port.
Sadly we have not been given the requirement of the game for both AMD CPUs and GPUs, which is sad to see.
MINIMUM
OS: Windows 7x64, Windows 8x64 (64-bit OS Required)
Processor: Intel Core i5-4460 (3.40 GHz) or better; Quad-core or better
Memory: 4 GB RAM
Graphics: NVIDIA GeForce GTX 650 (2GB) or better (DirectX 11 card Required)
DirectX: Version 11
Hard Drive: 28 GB available space
Sound Card: DirectX 9.0c compatible sound card
RECOMMENDED
Processor: Intel Core i7-4790 (3.60GHz) or better; Quad-core or better
Memory: 8 GB RAM
Graphics: NVIDIA GeForce GTX 760 (DirectX 11 graphic card required)
DirectX: Version 11
Sound Card: DirectX 9.0c compatible sound card (Surround Sound 5.1)
Metal Gear Solid V will be releases on PC, PS4, PS3, Xbox One and Xbox 360 on September 1st, with Metal Gear Online coming later on October 6th on consoles and January 2016 on PC. You can learn more about the Metal Gear Solid V's story and see new screenshots from Gamescom here.
You can join the discussion on Metal Gear Solid V's System requirements on the OC3D Forums
«Prev 1 Next»
04-08-2015, 07:40:07
xnax2802
Looks like I'm gonna need a new graphics card soon...Quote
04-08-2015, 07:55:50
Tripp
Won't have any trouble running it *touches wood*Quote
04-08-2015, 15:00:16
TheF34RChannel
I was excited about this until I played the the short one and found I could not set the keyboard for lefties. I expect the same problem with this one.Quote
