Metal Gear Solid V will be 1080p on PS4 and 900p on Xbox One
Metal Gear Solid V's Launch Date moved forward on PC
Metal Gear Solid V will be 1080p on PS4 and 900p on Xbox One, with both versions having a framerate of 60FPS.  This game will also be released on last generations consoles, the PS3 and Xbox 360, with both versions working at 720p 30FPS, which is a big reduction in both the framerate and resolution when compared to the current generation release.
This comes days afte rhte PC system requirements of the game have been released.
Metal Gear Solid: The Phantom Pain system requirements released
Moving to the PC version, when compare the system requirements of The Phantom Pain to Metal Gear Solid V: Ground Zeroes PC requirements, The Phantom Pain is not significantly higher, with GPU requirements being exactly the same and the CPU requirements being lightly bumped up from an Sandybridge i5 to a Haswell based 4th generation i5. Hopefully this means that this game will be an equally good PC port.
Sadly we have not been given the requirement of the game for both AMD CPUs and GPUs, which is sad to see.
MINIMUM
OS: Windows 7x64, Windows 8x64 (64-bit OS Required)
Processor: Intel Core i5-4460 (3.40 GHz) or better; Quad-core or better
Memory: 4 GB RAM
Graphics: NVIDIA GeForce GTX 650 (2GB) or better (DirectX 11 card Required)
DirectX: Version 11
Hard Drive: 28 GB available space
Sound Card: DirectX 9.0c compatible sound card
RECOMMENDED
Processor: Intel Core i7-4790 (3.60GHz) or better; Quad-core or better
Memory: 8 GB RAM
Graphics: NVIDIA GeForce GTX 760 (DirectX 11 graphic card required)
DirectX: Version 11
Sound Card: DirectX 9.0c compatible sound card (Surround Sound 5.1)
Metal Gear Solid V will be releases on PC, PS4, PS3, Xbox One and Xbox 360 on September 1st, with Metal Gear Online coming later on October 6th on consoles and January 2016 on PC. You can learn more about the Metal Gear Solid V's story and see new screenshots from Gamescom here.
You can join the discussion on Metal Gear Solid V's Console resolution and Framerate on the OC3D Forums
«Prev 1 Next»
07-08-2015, 09:25:49
SpencerUk
Bigger question is will they sustain the 60fps.
I am looking forward to the game though!.
You can pick Day 1 edition up for about £32 at present..Well Pre-OrderQuote
07-08-2015, 15:03:59
yassarikhan786
I don't have a PS4 or an Xbone so I don't care. I'll be more than happy if I can run the game at 60+ fps on my rig.
I also want to see a good MGS4 PC port, but it probably won't happen.Quote
07-08-2015, 16:48:37
SpencerUk
Some comparison shots here..Looks like better lighting on PC so its not an Arkham Knight style port lolQuote
07-08-2015, 16:51:45
yassarikhan786
Yeah, the lighting is definitely superior on the PC. It's generally a lot sharper as well.Quote
07-08-2015, 16:57:21
SpencerUk
For anyone else that wants to see some of the differences, PC on the left obviously.
http://cdn.wccftech.com/wp-content/u...08/MGS-V-4.jpg
http://cdn.wccftech.com/wp-content/u...08/MGS-V-3.jpgQuote
