MSI announce their GTX 1080 Ti SEA HAWK EK X GPU
MSI has announced their new GTX 1080 Ti SEA HAWK EK X GPU, which comes with a pre-installed EK water block and a significant factory overclock.
This GPU will come with an MSI themed EK water block design, with both MSI and EK logos on the block itself and a custom MSI backplate. On this GPU's rear IO this GPU will feature dual HDMI 2.0 ports, dual DisplayPort 1.4 ports and a single DVI-D connection.
Below is a table that compares the base and boost clock speeds of MSI's GTX 1080 Ti SEA HAWK EK X with that of Nvidia's reference/Founders Edition model.
 GTX 1080 Ti Founders EditionEVGA GTX 1080 Ti SC2 Hybrid
GPU ArchitecturePascalPascal
Process node16nm16nm
SM Units5656
Cores per SM6464
CUDA Core Count35843584
ROPs8888
VRAM TypeGDDR5XGDDR5X
Memory Clock11008MHz11024MHz
VRAM Cappacity11GB11GB
Memory Bus Size352-bit352-bit
Memory Bandwidth484 GB/s484 GB/s
Base clock speed1480MHz1569MHz
Boost clock speed1582MHz1683MHz
TDP250W250W
Power Connection
1x 8-pin 1x 6-pin
1x 8-pin + 1x 8-pin
PCI Express PCIe 3.0PCIe 3.0
Right now MSI's new GTX 1080 Ti Sea Hawk EK X is available to Pre-order at overclockers UK for £899.99
You can join the discussion on MSI's GTX 1080 Ti Sea Hawk EK X on the OC3D Forums
«Prev 1 Next»
05-05-2017, 00:08:56
Excalabur50
There still a pretty nice card not too OTTQuote
