Nvidia RTX 3090 and RTX 3080 Specifications Leak
The specifications of Nvidia’s RTX 3090 and 3080 have been leaked through Videocardz, revealing the CUDA core counts, the TGPs and the memory specs of Nvidia’s upcoming Ampere products.
This report seemingly confirms that Nvidia’s RTX 3090 will utilise 24GB of GDDR6X memory, and it has been reported that the RTX 3080 will release with 20GB variants, suggesting that Nvidia wants to increase the memory capacities that are available on consumer graphics cards. However, Nvidia’s RTX 3080 will launch with 10GB models, which is more than enough for today’s gamers.
Nvidia’s RTX AMpere lineup will support Nvidia’s 2nd Generation Ray Tracing Cores and 3rd Generation Tensor cores, offer PCIe 4.0 connectivity and support both HDMI 2.1 and DisplayPort 1.4a.
With a TGP of 350W, Nvidia’s RTX 3090 will be powered by two 8-pin PCIe power connectors for many custom models. However, Nvidia’s Founders Edition version of this graphics card should use the company’s new 12-pin GPU power connector. Nvidia’s RTX 3090, RTX 3080 and RTX 3070 are all due to be announced next month and launch sometime in September.
Nvidia’s marketing mentions the company’s use of a 7nm manufacturing process, according to Videocardz. Below is a chart detailing the leaked specifications of Nvidia’s RTX 3000 series.
  RTX 3090  RTX 3080 RTX 2080 Ti FE RTX 3070
GPU GA102-300 GA102-200 TU102-300 GA104-300
Node 7nm 7nm 12nm 7nm
CUDA Cores 5248 4352 4352 ?
Boost Clock 1695MHz 1710MHz 1635MHz ?
Memory 24GB GDDR6X 10GB GDDR6X 11GB GDDR6 8GB GDDR6
Memory Clock 19.5 Gbps 19 Gbps 14 Gbps 16 Gbps
Memory Bus 384-bit 320-bit 354-bit 256-bit
Bandwidth 936 GB/s 760 GB/s 616 GB/s 512 GB/s
TGP 350W 320W 260W 220W
Nvidia RTX 3090 and RTX 3080 Specifications Leak  Nvidia RTX 3090 and RTX 3080 Specifications Leak
You can join the discussion on Nvidia’s leaked RTX 3090 and RTX 3080 specifications on the OC3D Forums.Â
