Philips unveils their 32" 4K 328P6VJEB monitor with UltraColor
Philips has unveiled their new 32" 4K 328P6VJEB monitor, which supports an ultra wide color gamut and gives professionals both a large resolution and screen size for professional photo and video editing.
This monitor is designed first and foremost for graphic designers, supporting 95% NTSC color gamut, which is much higher than the 72% gamut support that most modern monitors adhere to. This will allow this monitor to provide more colour depth and more natural tones, giving end users a fantastic color experience without the need for time-consuming color calibration.
This monitor will use a VA LCD panel and support a maximum refresh rate of 60Hz at 4K, with this display supporting standard 100x100mm VESA mounts for use with monitor arms and aftermarket monitor stands.
Below is a list of some of the Philips 328P6VJE 31.5-inch 4K monitor.
  • - LCD panel type: VA LCD.
  • - Backlighting technology: W-LED.
  • - Panel size: 31.5 inch / 80.1 cm.
  • - Aspect ratio: 16:9.
  • - Optimum resolution: 3840 x 2160 @ 60Hz.
  • - Viewing angle: 178° (H) / 178° (V), @ C/R > 10.
  • - Brightness: 300 cd/m².
  • - Display colours: 1.07 billion.
  • - Colour gamut: NTSC 95%.
This display will become available for purchase o this month for the price of £599, which is a reasonable price given this display's size, resolution and wide gamut colour support.
You can join the discussion on the Philips 32" 4K Ultracolor 328P6VJEB monitor on the OC3D Forums.
«Prev 1 Next»
03-11-2016, 04:18:50
Kushiro
Got the 40" version and its terrible for any color work... Hope this is better...Quote
