Valve reveals their “Index” VR headset – Puts Fidelity First
Now Valve has created their own headset design for SteamVR, complete with Valve Index controllers, Valve Index Base Stations, which use their Lighthouse 2.0 technology and an updated headset that offers a large resolution and refresh rate bump over HTC’s Vive. These products are available both on their own or as a complete package, making the headset suitable for existing owners of HTC’s Vive headset.Â
Now let’s get started with headset specs, the Valve Index uses two 1440×1600 screens which support 80Hz, 90Hz, 120Hz and 144Hz (experimental) refresh rates, packing a design that is said to reduce the “screen door effect” significantly while offering a field of view that is 20% wider than the HTC Vive. The headset also has two front-facing cameras, SteamVR 2.0 sensors and requires USB 3.0 and DisplayPort 1.2 connections for power and display connectivity.Â
Built into the headset there are also two 37.5mm off-ear speakers, which are designed to deliver high-quality audio while ensuring long-term comfort.Â
Below are the Valve Index’ PC system requirements. Both Windows and Linux/SteamOS are supported on the Valve Index
MINIMUM:
OS: Windows 10, SteamOS, Linux
Processor: Dual Core with Hyper-Threading
Memory: 8 GB RAM
Graphics: NVIDIA GeForce GTX 970, AMD RX480
Network: Broadband Internet connection
Additional Notes: Available DisplayPort (Version 1.2) and USB (2.0) Port Required
RECOMMENDED:
Processor: Quad Core
Graphics: NVIDIA GeForce GTX 1070 or better
Additional Notes: Available USB (3.0) Port Required for Headset Pass-Through Camera & USB Port Support
With the Index, Valve is targetting the high-end of the VR market, and as such the company is shipping their headset for £459.00 as a standalone product, though it is worth noting that the device requires VR controllers and base stations to function. Pre-orders will start on May 1st and Valve promises that early orders will ship before the end of June.Â
Only owners of HTC’s Vive will already have SteamVR ready controllers and base stations, making Valve’s £459.00 pricing an effective “upgrade cost” for owners of HTC’s SteamVR headset. If you want the full Index package, the pricing of Valve’s headset goes up t £919.00, accounting for the cost of Valve’s VR controllers and base station 2.0 units. Â
Â
When compared to Oculus’ Rift S headset, Valve’s offering provides users with higher-end specifications and pricing to match. The Oculus Rift S will cost $399 in the US, which is less than the Valve Index headset alone, making it much more affordable for the mass market. Oculus’ inside-out tracking will also make their headset easier to set up, while the Valve Index will require users to set up its comparatively complex base station 2.0 tracking system.Â
You can join the discussion on Valve’s Index VR headset on the OC3D Forums.Â
