XSPC Reveals R9 Fury X Water Block
Published: 26th June 2015 | Source: XSPC |
Not long after EKWB had revealed their R9 Fury X waterblock XSPC has revealed their competing block which will be a thicker 2 slot wide block which is made to XSPC's usual style.
Since the R9 Fury X will only be available with AMD's Stock cooler, water block manufacturers are going to be able to make waterblocks which will be compatible with any Fury X, regardless of make or model as every Fury X PCB will be exactly the same.
With the GPU already being cooled by a AIO water cooler some of you may wonder why dedicated water blocks are necessary, but the answer is simple, to decrease the temperatures of your GPU core even further and to allow some more potential headroom for overclocking.
You can join the discussion on the XSPC R9 Fury X water block on the OC3D Forums.
XSPC has just revealed their R9 Fury X water block. http://t.co/3pDs6GONCC pic.twitter.com/1MDDFMWyVX
— OC3D (@OC3D) June 26, 2015
I actually like the looks of XSPC´s blocks. They are sleak and nice.
In comparison the EK one looks a lot more sleek.Quote
I use this style block on a 290x and a GTX 670 which I like the look of but on this with its shape it does not look nice in the pictures.Quote
