Zotac has unveiled their water cooled GTX 1080 Arctic Storm
Published: 11th August 2016 | Source: Techpowerup |
Zotac has unveiled their water cooled GTX 1080 Arctic Storm, which will use the same PCB as the GTX 1080 AMP Extreme and features RGB illumination on the clear acrylic water block.
This GPU will feature a factory overclock of 1632MHz base and 1733MHz boost on the GPU core with Nvidia's reference 10GHz GDDR5X memory clock speeds. This GPU will feature a full cover water block, though at this time we do not know who manufactures it. The GPU will also feature a Zotac banded backplate at stock, giving this GPU a rather industrial look and feel.
RGB LEDs are mounted on the GPUs water block, allowing the card to be illuminated with the controlled provided by Zotac's FireStorm overclocking utility.
At this time Zotac has not announced the final pricing of this GPU, though we expect that it will be Zotac's most expensive GTX 1080 model.
You can join the discussion on Zotac's GTX 1070 Arctic Storm on the OC3D Forums.
Zotac has unveiled their water cooled GTX 1080 Arctic Storm.https://t.co/GPZRr0qu71 pic.twitter.com/vp2WkVlB5q
— OC3D (@OC3D) August 11, 2016
Probably void soon anyway as there's a "secret" Nvidia event in London going on with Luke from LTT, Paul and Kyle and a few others, 1080 Ti most likely.
*EDIT* Oh and Zotac - what are those things protruding from the card?? Barbs a la 2002??Quote
