Zotac Launches their Liquid Cooled RTX 2080 Ti ArcticStorm Graphics Card
This GPU boasts a 16+4 phase power system and Spectra 2.0 lighting
Zotac has officially launched their liquid cooled RTX 2080 Ti ArcticStorm graphics card, merging Nvidia's top-tier Geforce graphics card with an ultra-high-end 16+4 phase VRM and a custom water block that ships with integrated SPECTRA 2.0 RGB lighting.
The RTX 2080 Ti ArcticStorm is expected to act as Zotac's new gaming flagship, sitting above their RTX 2080 Ti AMP Extreme. Lighting-wise the graphics card multiple addressable RGB lighting zones that can be controlled using Zotac's new FireStorm software.
With this ArcticStorm graphics card, Zotac has used laser etching to allow their RGB lighting to illuminate several sharp features, from Zotac's V-shaped gaming logo to several angular outlines and shapes across the water block's surface.
Zotac's ArcticStorm water block is made with nickel plated copper and uses 0.3mm micro-channels to deliver optimal cooling performance when combined with a compatible water cooling loop.
Specifications-wise, Zotac ships with RTX 2080 Ti ArcticStorm with a stock boost clock of 1575MHz, which is a mere 35MHz above Nvidia's reference RTX 2080 Ti and 60MHz below Nvidia's RTX 2080 Ti Founders Edition. This can be improved via overclocking, which can be done manually and using Nvidia's OC scanner technology.
Zotac ships this graphics card with two 10mm ID (internal diameter) tubing water cooling barbs, which are compatible with the GPU's G1/4 thread 3/8" mounting locations. This block is also compatible with 3rd party water cooling accessories.
You can join the discussion on Zotac's RTX 2080 Ti ArcticStorm on the OC3D Forums
«Prev 1 Next»
19-02-2019, 09:18:10
Peace
Looks rather epic if you ask me! Quote
