Corsair announced their GLAIVE RGB Gaming mouse
Corsair announced their GLAIVE RGB gaming mouse, which comes with six programmable buttons, DPIs of between 100 and 16,000.
This new mouse was developed by Corsair in co-operation with PixArt, using a custom version of their PMW3367 sensor which has DPI ranges that can be adjusted with 1DPI increments to allow users to have perfectly defined precision tuning. Corsair has also designed this mouse with OMRON key (left and right mouse) switches to ensure a lifetime of up to 50 million clicks, as well as a USB refresh rate of 1000Hz/1ms to ensure ultra fast reaction times.
The GLAIVE will also come with three interchangeable magnetic grips, which will allow this mouse to be customised to suit the user’s preferences, be it a smooth grip, a rubberised grip or a wide-grip with a thumb rest.
Corsair’s Glaive RGB mouse, as the name suggests, will offer support for RGB lighting, with several customisable zones which can be defined by custom profiles or even using game-specific lighting settings. Below are the Glaive’s full specifications.
Specifications:
- – Contoured shape: Designed so you can game longer without fatigue.
- – Custom, gaming grade 16,000 DPI optical sensor: Ultra-accurate and high-speed tracking engine. Native 16,000 DPI resolution, settable to 1 DPI steps, can be custom tuned to virtually any type of mouse pad.
- – Interchangeable thumb grips: Choose between three thumb grip styles for a tailored fit.
- – Onboard profile storage: Saves lighting effects, macros and DPI settings for universal access to your profile on any PC, without the need for drivers or additional software.
- – Surface calibration tuning utility: Optimizes sensor precision and responsiveness for your playing surface.
- – High-performance Omron switches rated for 50 million clicks: Custom tuned for gaming, providing an ultrafast response and reliability over time.
- – Dynamic multicolor three-zone backlighting: Customizable RGB backlighting immerses you in the game by providing nearly unlimited lighting adjustability.
- – Aluminum scroll wheel with rubber grip: Ensures solid response and accuracy.
- – Ultrafast 1ms lag-free gameplay: Supports up to 1000Hz/1ms refresh rate for a near instant response to your movements.
Right now Corsair’s Glaive RGB mouse is priced at £69.99 on Corsair’s website.
You can join the discussion on Corsair’s new Glaive Mouse on the OC3D Forums.
