Sabrent gives Valve’s Steam Deck a connectivity boost with their “Gaming Hub” add-on
Sabrent gives Valve’s Steam Deck more USB ports with their new “Gaming Hub” add-on
Sabrent have given Valve’s Steam Deck a major upgrade with their new USB “Gaming Hub” add-on. With it, users of Valve’s PC gaming handheld can have access to more connectivity options using a form-fitted, colour matched USB hub add-on. Users will be able to charge their Deck systems with up to 100 watts of power while offering users the connectivity of two USB 3.0 ports.
This add-on addresses one of the problems that users of systems like the Steam Deck face. Most of these handheld gaming systems have very few USB ports. Once you connect your devices charger, you will have little to no connectivity options. With this add-on, you can charge your device while maintaining access to two additional 5Gbps USB ports. This is great for anyone who pairs their Steam Deck with portable storage devices, keyboards, mice, or other accessories.
Sabrent’s new connectivity hub for Valve’s Steam Deck is now available to purchase on Amazon in the US. We expect this product to be available in Europe soon.
Sabrent’s solution is designed to fit Valve’s Steam Deck perfectly and to work in a driver-free way. This makes making it an easy add-on to set up and use. It also supports macOS and Linux systems, though it has been made with Valve’s Steam Deck in mind.
You can join the discussion on Sabrent’s USB Type-C Gaming Hub for Valve’s Steam Deck on the OC3D Forums.
