The USB 3.2 specification has been published
To understand the performance upgrade the USB 3.2 provides we need to look at the development of USB Type-C, which is the first USB cable standard to offer support for multi-lane operations. This ensures that this standard has the ability to scale moving forward.
This means that USB 3.2 ports will be able to use existing USB 3.1 cables to offer double the data transfer speeds of USB 3.1, though this means that users will need to wait for a whole new generation of devices that offer USB 3.2 support.
The move to USB 3.2 will officially make USB as fast as Thunderbolt 2.0, which is great news for USB, though this also means that Thunderbolt 3 is still 2x faster than USB 3.2.
Key characteristics of the USB 3.2 solution include:
– Two-lane operation using existing USB Type-C cables
– Continued use of existing SuperSpeed USB physical layer data rates and encoding techniques
– Minor update to hub specification to address increased performance and assure seamless transitions between single and two-lane operation
At this time it is unknown when we will first see devices use USB 3.2, though it is not expected to be soon given the early state of the standard.
You can join the discussion on USB 3.2 on the OC3D Forums.
