ADATA’s XPG SPECTRIX D41 RGB DDR4 memory has hit 5GHz under air cooling
Every race needs competitors, and ADATA has secured for themselves a prime position within the overclocking space by achieving DDR4 clock speeds of 5GHz on a dual-channel XPG SPECTRIX D41 RGB DDR4 memory kits. These DIMMs can offer speeds of 4.6GHz out of the box, with ADATA pushing their product to even greater heights with Intel’s i7 8700K and MSI’s Z370I GAMING PRO CARBON AC.
While this kit isn’t available off the shelf, 5GHz is still a huge milestone for memory manufacturers, especially under standard air cooling. Just a few short years ago, 5GHz memory overclocks required LN2 cooling and extremely high operating voltages, making the speed impossible to maintain for day-to-day use. So far only G.Skill (link) and ADATA have revealed their potential to create 5GHz air cooled DDR4 memory.
Below is a comment from ADATA’s Director, Tom Chan, using this feat as an example of the company’s passion for performance and their R&D capabilities.
We are extremely thrilled to have reached this amazing milestone back in March, because it demonstrates once again the robust R&D capabilities of ADATA, and the passion that we have for advancing memory performance,
For us, the next critical step will be working to make this more than just a technological milestone, but something that will be accessible to gamers, overclockers and others, so that they can ultimately benefit from this amazing performance.
Much like G.Skill’s 5GHz memory overclock, ADATA used Samsung B-die memory yo create their 5GHz capable air cooled memory kit, with Samsung’s B-die memory already being famous amongst overclockers for their high performance and wide compatibility.
You can join the discussion on ADATA hitting 5GHz on air with their DDR4 XPG Spectrix memory on the OC3D Forums.
