addlink reveals its AddGame Spider 4/X4 series DDR4 memory modules
addlink, the Taiwanese technology company, has just revealed its first AddGame branded overclocking memory, launching with both RGB and non-RGB models and memory speeds of up to 4600MHz.
With their new SPIDER 4 series modules, Addlink’s offering users module capacities of 8GB, 16GB, and 32GB, a low profile 36mm module height and module CL timings that range from CL16-20. On the premium end of the market, the company has their SPIDER X4 RGB modules, which offer users the same specifications with a low profile 37mm module height and RGB illumination support.
AddGame’s SPIDER X4 RGB modules support lighting control through software solutions like  Asus Aura Sync, MSI Mystic Light, ASRock Polychrome Sync, and Gigabyte RGB Fusion. This allows addlink’s RGB memory modules to be synchronised with the rest of your system’s lighting.
What follows is Addlink’s Press Release.
Press Release – addlink Launches High-Performance AddGame SPIDER 4 and SPIDER X4 Series Gaming Memory
Building on the success of the AddGame series (A division of addlink Technology Company), addlink is proud to announce Addgame’s latest high-performance overclocking memory, SPIDER 4 and SPIDER X4 DDR4.
AddGame Spider X4, Dynamic Multi-Zone RGB
Spider X4 features a large wide-angle lighting strip with dynamic multi-zone RGB lighting, combines with a premium aluminum heat spreader. Offering speeds up to 4600MHz paired with quick CL16-20 timings. It’s also perfectly compatible with Asus Aura Sync, MSI Mystic Light, ASRock Polychrome Sync, and Gigabyte RGB Fusion software to provide a smooth, synchronized lighting effects.
AddGame SPIDER 4, Black Spider Totem Overclocking Memory
Spider 4 also provides speeds up to 4600MHz paired with quick CL16-CL20 latencies. Not only is the ICs were tested under the most stringent conditions, but the pure aluminum heat dissipation was also proved to maximize cooling for the ultimate performance.
Low Profile Design, Ready for AMD Ryzen
AddGame Spider 4/X4 are designed for heavy gamers and hardware enthusiasts. Both models have a low-profile design that can fit into most motherboards even with small chassis systems, e.g., mircroATX and mini-ITX motherboards. Spider 4/ X4 have passed 100% factory tests at product speeds, supported by a lifetime warranty, Intel XMP-ready for easy on-step overclocking and are compatible with the latest Intel/AMD platform.
Spider 4/X4 are now available at authorized addlink distribution partners and will be available on Amazon in August 2021.
You can join the discussion on addlink’s AddGame Spider 4 and X4 series DDR4 modules on the OC3D Forums.
addlink reveals its AddGame Spider 4/X4 series DDR4 memory modules Â
