DRAM manufacturer Netac aims high with their DDR5 R&D spending – 10,000MHz Speeds Promised
Netac has already received DDR5 memory modules from Micron, engineering sample ICs with the Z9ZSB designation. These modules reportedly operate with CL40 timings and 2Gx8 capacities.
With DDR5 memory modules offering native speeds of 4800MHz, as specified by JEDEC’s DDR5 standards, Netac is aiming high with their R&D developments. That said, DDR5’s new features will likely enable increased memory overclocking potential, and JEDEC’s standards are usually low to ensure high levels of memory manufacturability. With this in mind, there is little reason why high-end 10,000 MHz DDR5 memory modules won’t be possible.
One of DDR5’s primary benefits is that their power delivery is controlled on the module. This frees DRAM modules from the control of motherboards, enabling finer levels of voltage regulation and higher potential operating voltages for DDR5 modules. Team Group has already confirmed that their T-FORCE Power Management Integrated Circuit (PMIC) has been designed to deliver voltages of up to 2.6 V, which is a huge potential increase over the 1.1/1.2V that standard JEDEC DDR5 memory modules should run at.
With tight power regulation and highly binned DDR5 memory modules, 10,000 MHz DDR5 memory modules should be possible. That said, these speeds need to be supported by future processors, not just by DDR5 modules. Intel and AMD will need to increase the performance of their integrated memory controllers to make use of these new DRAM modules, especially if manufacturers start to target speeds beyond JEDEC’s standards early in DDR5’s life cycle.
Over the next few years, DDR5 memory will become increasingly mainstream, delivering higher levels of per module bandwidth to consumers. In time, DDR5 memory modules should also normalise larger per DIMM capacities, making 16GB and 32GB DRAM capacities a lot more common within mainstream systems.
You can join the discussion on Netac’s plan to create 10,000MHz DDR5 memory modules on the OC3D Forums.
