G.Skill Launches Crazy 6-Channel DDR4 Trident-Z Memory Kits for Intel’s Xeon W-3175 CPU
With this mightly Xeon comes a new CPU platform, shipping on the Intel’s LGA3647 socket. To enable overclocking, users also require custom motherboards such as the ASUS ROG Dominus Extreme, which ships with MSRP pricing of over $1000, thanks to the VRM and memory requirements of the platforms.
Now that the need for hex-channel DDR4 memory had entered the mainstream mindset, G.Skill has stepped up to become the first manufacturer to provide bespoke memory kits that are designed specifically for the task, shipping under the company’s Trident Z Royal branding.
These kits will ship with six or twelve modules, with capacities that range from 48GB (6x8GB) to 192GB (12x16GB) while also offering speeds of 3200MHz, 3600MHz and 4000 MHz. All of these memory kits are validated on an ASUS ROG Dominus Extreme motherboard and an Intel Xeon W-3175X processor.
In terms of raw transfer rate, G.Skill’s latest offerings deliver transfer rates that extend way beyond what is possible on Intel’s X299 platform, with their high-end 4000MHz 6-channel memory kits offering read bandwidths as high as 122GB/s.
All of G.Skill’s Trident Z Royal memory kits are created using Samsung B-die memory ICs, which are designed to offer high performance levels while maintaining reasonable voltage requirements. The chart below lists all available configurations of G.Skill’s Hex-channel Trident Z Royal memory kits.
G.Skill’s latest Trident Z Royal Hex-channel memory kits will be available through the company’s network of distribution partners and retailers.
You can join the discussion on G.Skill’s Hex-channel Trident Z Royal memory modules on the OC3D Forums.
