G.Skill launches their Ryzen-oriented Trident Z Neo series of DDR4 memory DIMMs
G.Skill launches their Ryzen-oriented Trident Z Neo series of DDR4 memory kits
Coinciding with the launch of AMD’s Ryzen 3rd Generation processors, G.Skill has released their Trident Z Neo series of DDR4 memory DIMMs, which are designed with X570 in mind with speeds of up to 3600MHz and tight CL14 timings.
Alongside this speed bump for Ryzen memory comes a new RGB LED lighting design, which offers users 8-zone lighting and the same level of software support as the company’s existing TurdentZ Royal DIMMs, with lighting control coming from G.Skill’s software as well as through utilities like ASUS Aura Sync, Gigabyte RGB Fusion, MSI Mystic Light, and ASRock Polychrome.
Each DIMM comes with a 10-layer PCB and can ship in kits of up to 64GB (4x16GB DIMMs). Each kit comes pre-tested on an ASUS Crosshair VIII Formula motherboard with an AMD Ryzen 5 3600 processor.
The table below notes the capacities and specifications that are offered by G.Skill’s latest DDR4 DIMMs, which can feature timings as tight at 14-15-15-35 at 3600MHz in 2x 8GB and 4x8GB kits.
Each DIMM is designed to offer a bold contrast between black brushed aluminium and powder coated silver to deliver an impactful look.
 G.Skill’s Trident Z Neo series of Ryzen 3rd Generation Optimised memory kits will be available at retailers starting today.
Our review of AMD’s Ryzen 3rd Generation 3700X and 3900X processors is available to read here.
You can join the discussion on G.Skill’s Ryzen-optimised Trident Z Neo series of DDR4 memory kits on the OC3D Forums.
