Published: 22 September 2017 |
Source:
G.Skill - PR |
Author:
G.Skill releases Ryzen Optimised Trident-Z RGB DDR4 memory
G.Skill has released several new kits of Ryzen optimised memory modules, which are purpose-built to offer the highest levels of compatibility possible on AMD’s latest consumer CPU platforms.
These kits come in both high-speed variants and models that are designed to work best when all of your motherboard’s DIMM slots are occupied, with kits of up to 4x16GB and 8x16GB for Ryzen and Threadripper CPUs respectfully.
The fastest speeds that these kits offer is 3200MHz at 14-14-14-34 timings, with G.Skill offering 2x8GB and 4X8GB kits for Ryzen and Threadripper respectfully.
To distinguish these new kits from Intel-optimised kits users should look for an X at the end of the model number of your chosen G.Skill memory kit.
These new Ryzen and Thradripper memory kits will be available in October, releasing through G.Skill’s authorised distribution network of partnered retailers.
You can join the discussion on G.Skill’s Ryzen-Optimised Trident-Z DDR4 memory kits on the OC3D Forums.
