HyperX to introduce new high speed DDR4 memory kits
HyperX to introduce new high-speed DDR4 memory kits
HyperX is set to introduce several new high-speed DDR4 memory kits, with speeds ranging from 2,400MHz to 4,000MHz. All of these kits will come with stock voltages of 1.35 volts and feature a range of CAS timing values.
These new kits come with built-in XMP profiles that are designed to run with Intel’s newest X299 platform, though there is no official mention of Ryzen support.
Below is a list of HyperX’ upcoming memory speeds and their rated CAS latencies. All of this kits will be available with up to 4-channel kits with 8GB DIMMs, with all kits except 3333MHz modules coming with 16GB DIMMs.
– 2400MHz at CL12
– 2666MHz at CL13
– 3000MHz at CL15
– 3333MHz at CL16
– 3600MHz at CL17
– 4000MHz at CL19
– 2666MHz at CL13
– 3000MHz at CL15
– 3333MHz at CL16
– 3600MHz at CL17
– 4000MHz at CL19
At this time pricing and release information on these kits are unknown, though they are expected to release within the next few weeks at online retailers.
You can join the discussion on Kingston’s new high-speed DDR4 memory kits on the OC3D Forums.
