Intel launches Optane DC Persistent Memory DIMMs – A tier between DRAM and SSD storage
This memory should not be confused with Intel’s existing Optane storage drives, as while the underlying memory is the same, these new modules are designed for a very different purpose. Intel’s Optane DC persistent memory modules are designed to be used as an extension and accelerator for DRAM.
For starter, Intel’s Optane DIMMs will offer capacities of 128GB, 256GB and 512GB per DIMM, offering storage densities that are in a different league than today’s DDR4 DRAM.
The move to a DIMM form factor has also allowed Intel to cut down the latency of their Optane memory significantly, making it a lot more viable as a DRAM replacement or extension, as PCIe-based solutions have several more steps to take before accessing CPU resources. Moving Optane onto a DIMM bring Optane as close to the CPU as DDR4 DRAM, giving it the characteristics it needs to accelerate large data-driven workloads.
Intel wants Optane to sit as a storage medium that comes after DRAM and before system memory, with a system’s most important data moving to DRAM while less sensitive data is stored in Optane. When the information on Optane is required, systems can access it exceptionally quickly thanks to its close to the CPU DIMM design, offering significant latency and throughput benefits over an equivalent Optane-based PCIe SSD storage medium.
Intel is currently sampling their Optane DC DIMMs to customers and has showcased preview systems with 192GB of DRAM and 1TB of Optane persistent memory. Broader availability for Intel’s Optane DC DIMMs is expected in early 2019.
Optane DC memory will be supported on Intel’s next-generation of Xeon Server processors, though at this time it is not known whether or not this functionality will be limited to select high-end platforms. Optane DC will not be supported on Intel’s existing products, which also means that Optane DC will not function with AMD processors.
Intel’s Optane DC memory has the potential to be transformative for specific applications, or at a minimum allow server manufacturers to create systems with vast banks of memory without the extremely high costs of using DDR DRAM exclusively.
The problem here is that the hardware ecosystem is in its early days, Optane memory is a relatively unproven memory type, and the software ecosystems will need to adapt to these hardware changes.
You can join the discussion on Intel’s new Optane DC persistent memory DIMMs on the OC3D Forums.
