OCZ Technology Unveils 2000MHz Triple Channel Memory Kits for Intels Core i7
OCZ Technology Unveils 2000MHz Triple Channel Memory Kits for Intel Core i7 processors, with the Introduction of the Extreme-Performance Blade Series.
OCZ Technology Group, Inc., a worldwide leader in innovative, ultra-high performance and high reliability memory, today introduced the Blade Series Triple Channel Memory kit, the latest maximum-performance RAM designed specifically for the Intel® Core⢠i7 processor / Intel® X58 Express Chipset. At DDR3-2000 CL 7-8-7, the Blade Series harnesses industry-leading speeds at the low voltage required to safely run Core i7âs triple channel mode. With the ideal combination of all the factors that formulate the ultimate memory solutionâ density, speed, latency, and an effective new cooling designâthe Blade 2000 kit is guaranteed to please enthusiasts looking to take the hottest Intel platform to new heights.
âWithin any extreme performance computer, the memory subsystem holds a key position for storing and delivering the data to the processor in the fastest possible manner,â commented Dr. Michael Schuette, VP of Technology Development at OCZ Technology. âUsing a triple channel configuration custom tailored towards Intelâs Core i7 platform, the latest OCZ Blade Series kits epitomize the pinnacle of memory technology by delivering 2000MHz data rate for an available bandwidth of 35GB/sec to satisfy even the most data-hungry processor in the current marketplace.â
The Blade Series heatspreader aims to enhance heat dissipation to improve the longevity and stability of the modules while keeping a sleek, low profile. The new propriety design has numerous channels that increase the surface area to more efficiently offload heat away from the memory chips and PCB. Push your gaming or overclocking rig to the extreme with the superior thermal solution and unmatched speeds of the high-end Blade Series memory modules.
Blade 2000 modules will be showcased at the upcoming CES 2009 show, and will be available shortly afterwards. OCZ continues to expand its extensive product offerings and deliver the landmark speeds called for by the enthusiast community. OCZâs Blade 2000 Triple Channel kits are 100% hand-tested for quality assurance and compatibility with the latest Intel Core i7 motherboards, and are backed by the industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
OCZ DDR3 PC3-16000 Blade Series
Discuss OCZ’s 2000MHz Triple Channel Memory Kits with Blade Series heatspreader in our forum
