Samsung confirms 10.7 Gbps LPDDR6 memory for next-gen systems
Samsung plans to showcase its 10.7 Gbps LPDDR6 memory at CES 2026
Samsung has confirmed its plan to showcase its new 12nm LPDDR6 memory modules at CES 2026. The LPDDR6 memory standard was ratified earlier this year, and Samsung appears to be one of the first companies to create new memory modules using it. With speeds of 10.7 Gbps, it exceeds the maximum speeds of existing LPDDR5 and LPDDR5X memory chips. This is excellent news for new mobile platforms and AI users, as memory bandwidth limitations can impact overall device performance.
With its new memory, Samsung promises approximately 21% more memory efficiency than before. Additionally, LPDDR6 promised enhanced security mechanisms for data integrity. These features make LPDDR6 more suitable for industrial and mission-critical use cases, at least when compared with LPDDR5/LPDDR5X.
As AI, edge computing, and mobile platforms continue to evolve, the demand for faster, more efficient, and secure memory is reaching new heights. LPDDR6 is a next-generation memory solution engineered to meet these demands. Built on an advanced 12nm process, LPDDR6 supports blazing-fast data rates of up to 10.7Gbps and features an expanded I/O count to maximize bandwidth—ideal for data-intensive mobile applications, edge computing, and AI workloads. A dynamic power management system intelligently tunes power consumption by workload, delivering approximately 21% better energy efficiency than its predecessor. LPDDR6 also introduces enhanced security mechanisms to safeguard data integrity, expanding its role beyond mobile into industrial and mission-critical AI environments. With its scalable, cross-platform architecture and eco-conscious design, LPDDR6 strikes a powerful balance between performance, energy savings, and reliability—making it an essential memory solution for the intelligent systems of tomorrow.
LPDDR6 will be a valuable memory technology for future laptops and gaming handhelds. These devices are often bandwidth-starved, so any increase in memory bandwidth is welcome. With starting speeds of 10.7 Gbps, it seems likely that more refined versions of LPDDR6 will deliver bandwidth levels comparable to those of early GDDR6 memory modules. This signals a bright future for the LPDDR standard and the gaming devices that it will enable.
You can join the discussion on Samsung’s LPDDR6 memory on the OC3D Forums.
