TeamGroup creates an insane 256GB T-Force Xtreem ARGB DDR4-3600 memory kit
With per DIMM capacities of 32GB, TeamGroup’s new high-capacity 8-DIMM memory kits can deliver an insane amount of storage density of users of Intel’s Cascade Lake-X and AMD’s Ryzen Threadripper series processors, operating with primary timings of CL 18-22-22-42.
While these are not the lowest latency DRAM modules available, you would be hard-pressed to find 32GB DRAM modules that responded at a faster rate, especially when used in an 8-DIMM configuration.
With speeds of 3600 MHz, these modules sit at the sweet spot of memory frequency when combined with AMD’s CPU Infinity Fabric. This factor makes these DIMMs ideal for Ryzen Threadripper powered systems. These T-Force Xtreem DIMMs are designed to feature a mirror-like finish with ARGB illumination, adding a little dazzle to the otherwise dull aesthetics of workstation-focused memory modules.
Whether you are working CAD models, editing video/audio, or doing some scientific computing, this 256 GB kit should be more than enough to satisfy your computing needs, even if you add a few extra Chrome tabs into the mix.
You can join the discussion on TeamGroup’s insane 256GB T-Force Xtreem ARGB memory kit on the OC3D Forums.
