Thermaltake Releases High Capacity TOUGHRAM XG RGB 4000/3600 MHz DDR4 Memory Kits for Content Creators
Thermaltake’s latest DRAM kits are targeting content creators, those who want a mix of both speed and raw capacity. That’s what Thermaltake’s newest TOUGHRAM XG RGB DDR4 modules are all about, offering customers per-DIMM capacities of up to 32GB while maintaining speeds of 3600MHz and 4000MHz.
These new TOUGHRAM XG memory modules are designed to support the latest AMD and Intel platforms, using “tightly-screened ICs” and “ten-layer PCB[s]” to ensure signal integrity. These DRAM kits have also been manufactured with the same RGB lighting as their other TOUGHRAM XG RGB modules, and a compelling heatsink design.
For content creators, DRAM capacity is a big deal, as lacking enough memory will at a minimum cause your programs to slow down to a crawl. With Thermaltake’s new 16GB and 32GB modules, which are available in 2-DIMM 32GB/64GB kits, the TOUGHRAM XG RGB series should deliver enough DRAM for your specific needs.
Each TOUGHRAM XG RGB module features 16 high-lumen addressable RGB LEDs, which are placed on an X-shaped light bar that features eight independent lighting zones. Users of Thermaltake’s DRAM can control these RGB LEDs through software, like Thermaltake’s NeonMaker utility. Thermaltake’s TOUGHRAM software can also be used to adjust lighting effects.
You can join the discussion on Thermaltake’s new high-capacity TOUGHRAM XG RGB DDR4 memory kits on the OC3D Forums.
