VIPER Gaming reveals it high-speed VIPER VENOM DDR5 high performance memory kits
VIPER Gaming will offer gamers DDR5 memory with speeds of up to 6200 MT/s in Q1 2022
VIPER, a sub-brand of Patriot, have just revealed a new line up of DDR5 memory kits, which are due to launch in Q1 2022 worldwide with speeds that range from 4800 MT/s to 6200 MT/s.
These new VIPER Gaming series DDR5 modules will be available with and without RGB lighting support, and with per kit capacities of 16 GB to 32 GB. These modules are designed to be used with Intel’s new 12th Generation Alder Lake processors, offering users the bandwidth they need to power through gaming and productivity workloads.
Sadly, VIPER Gaming has not supplied is with the CL timings and pricing information for their DDR5 memory modules, though this information should become available soon. What follows is Viper Gaming’s Press Release.
PR – VIPER Gaming Announces the VIPER VENOM DDR5 Performance Memory Kits
VIPER, a trademarked brand of PATRIOT, is excited to announce the availability of the new VIPER VENOM RGB and non-RGB DDR5 high-performance DRAM modules which will be available in Q1 2022. The VIPER VENOM DDR5 memory modules provide enhanced speeds ranging from 4800 MHz to 6200 MHz with kit capacities of 16 GB to 32 GB equipped with the exclusive VENOM heatspreader design with an option for RGB illumination catering to both PC hardware enthusiasts and hardcore gamers.
VIPER VENOM RGB DDR5 modules come with the stylish VENOM heatshield design with a new design to combine the LED light bar and the heatshield. The RGB light bar is an entirely new design with updated synchronization software and illumination patterns. The unique architecture of DDR5 has localized voltage adjustments based on a locked/unlocked PMIC (power management integrated circuit) and SPD HUB (serial presence detection), which provides simultaneous monitoring, threshold protection, intelligent voltage control, and power management to achieve more comprehensive voltage control.
Furthermore, the on-chip ECC function enables active error correction to improve data integrity and enhance performance and stability. Each module is constructed with a ten-layer PCB to offer excellent signal integrity and unmatched stability with a physical height tailor-made to fit most CPU coolers in the market without interference.
The VIPER VENOM DDR5 Memory Series will be available Q1 2022 in major retailers worldwide with two packages with RGB and Non-RGB models.
You can join the discussion on Patriot’s VIPER Gaming VENOM DDR5 modules on the OC3D Forums.
