MSI launches their Claw 8 AI+ and Claw 7 AI+ Gaming handhelds
MSI launches two Intel Lunar Lake-powered PC gaming handhelds with Xe2 graphics
MSI has officially launched two new Claw AI series handhelds for PC gamers. These devices are powered by Intel’s new Core Ultra 7 258V Lunar Lake processors and feature 32GB of LPDDR5X-8533 memory. Thanks to their new Xe2 graphics chips, these handhelds promise to deliver much more gaming performance than their predecessor.
MSI’s new Lunar Lake handhelds come in Claw 8 AI+ and Claw 7 AI+ flavours. Both feature the same Lunar Lake processors, though the 8 features a larger 8-inch 1920×1200 screen, a larger battery, and redesigned controls. The Claw 7 AI+ is more similar to MSI’s original Claw handheld, with its 7-inch 1080p screen. This model uses the same chassis design as its last-gen counterpart but with some enhancements. Note that both of these handhelds now feature two USB Type-C Thunderbolt 4 ports. Additionally, both models feature 32GB of system memory, which is more than enough for any gaming workload.
Both models ship with MSI’s Center M software, which makes it easier for users of the handheld to navigate through their games. Furthermore, these new Windows 11 Copilot+ handhelds also support Android apps through MSI’s “App Player.”
Sadly, Pre-orders for these new MSI Claw AI gaming handhelds are not available in the UK at this time. However, MSI fans in the US can pre-order this handheld starting today. With its Xe2 graphics, Intel has promised competitive levels of gaming performance with AMD’s latest Strix Point Ryzen CPUs. However, it should be noted that AMD has not released any handheld gaming PCs that use their RDNA 3.5 graphics.
You can join the discussion on MSI’s new Lunar Lake-powered Claw gaming handhelds on the OC3D Forums.
Specifications: – MSI Claw 8 AI+
- Model Name
- MSI Claw 8 AI+ A2VM
- Processor
- Intel Core Ultra 7 processor 258V
- Operating System
- Windows 11 Home
- Chipset
- Integrated SoC
- Memory
- LPDDR5x-8533 Memory on Package, 32 GB
- Display
- 8″ FHD+ (1920 x 1200), 16:10, Touchscreen, 120 Hz Refresh Rate, 100% sRGB (Typical), 500 nits (Typical), VRR, IPS-Level panel
- Graphics
- Intel Arc 140V GPU
- Storage Slot
- Up to 1 TB PCIe Gen 4 SSD Easy Access
- Sensor
- 6-axis IMU, vibration motor
- Communication
- Wi-Fi 7 + Bluetooth v5.4
- Audio
- 2x 2 W Speakers, DTS sound effect, support Hi-Res Audio
- I/O Port
- 2x Thunderbolt 4 / DP/ USB Type-C (w/ PD 3.0 Charging)
- 1x microSD Card Reader
- 1x Audio combo jack
- 1x Power button with fingerprint Sensor
- Battery/Adapter
- 6-Cell, Li-Polymer, 80 Whr / 65 W USB Type-C PD 3.0
- Dimension – 299 (W) x 126 (D) x 24 (H) mm
- Weight – 795 g
- Color – Sandstorm
- OS – Win 11 (support App Player to play Android Mobile Game)
Specifications: – MSI Claw 7 AI+
- Model Name
- MSI Claw 7 AI+ A2VM
- Processor
- Intel Core Ultra 7 processor 258VV
- Operating System
- Windows 11 Home
- Chipset
- Integrated SoC
- Memory
- Display
- 7″ FHD (1920 x 1080), Touchscreen, 120 Hz Refresh Rate, 100% sRGB (Typical), 500 nits (Typical), VRR, IPS-Level panel
- Graphics
- Storage Slot
- 1x NVMe M.2 2230 SSD by PCIe Gen 4 x4
- Sensor
- Communication
- Wi-Fi 6E + Bluetooth v5.34
- Audio
- I/O Port
- Battery/Adapter
- 6-Cell, Li-Polymer, 54.5Whr / 65 W USB Type-C PD 3.0
- Dimension – 290 (W) x 117 (D) x 21.2 (H) mm
- Weight – 675 g
- Color – Black
