Valve officially launches its Steam Frame VR headset for £889
Valve has opened up Steam Frame registrations to eligible gamers
Valve has opened up a sign-up process for Steam Frame reservations, placing eligible applicants into a list that will be randomised to allocate initial pre-orders. On Thursday, September 17th, Valve will randomise the list and email the results within a day. Like other recent Steam hardware launches, Valve expects its early Steam Frame stock to sell out quickly.
Pricing and Specifications
Valve will release two models of the Steam Frame: a £889 256GB version and a £1089 1TB version. Both models feature a 4nm Snapdragon 8 Gen 3 SOC and 16GB of Unified LPDDR5X memory. Both models also include a MicroSD card slot and a rechargeable 21.6Wh battery. Aside from their storage specifications, both VR headset models share identical specifications.
Valve’s Steam Frame features two LCD panels, offering 2160×2160 resolution per eye. These panels can operate at 72 to 144 Hz, with Valve marking their 144Hz mode as “experimental”. The device also features Wi-Fi 7 and Bluetooth 5.4, plus 6-DOF tracking, inside-out cameras, and two Steam Frame Controllers. The device also comes with a free copy of Half-life: Alyx.
Note that Valve’s Steam Frame does not come with a power adapter. You can charge the device with any USB-C charger rated at 45W or higher. For £29, buyers can purchase a Steam Hardware 45W power supply unit with a 2.5m cable. Note that an ergonomic accessories kit is also available for the device for £59, which adds two controller hand straps, a headset top strap, and an extended light blocker.
Gamers can join Valve’s reservation list for their new Frame VR headset here.
Join the discussion on Valve’s Steam Frame VR headset on the OC3D Forums.
