Club 3D has created USB Type-C cables that can suit all of your power and data needs
Need a 240W USB Type-C cable that can also deliver 40 Gbps speeds?
Published: 3rd May 2022 | Source: Club 3D |
Need certified USB Type-C cables with clear labels on each cable? Club 3D have the cables you need
I don't know about you, but buying USB Type-C cables can be a chore. Yes, standard unbranded USB cables are useful for many applications, but if you are a high-end user, it can be hard to buy a USB cable that meets your requirements, be it in terms of data transfer speeds or power delivery.
Thankfully, manufacturers are starting to make things a little easier, with USB-IF giving cable makers new markings that can be used to label cables with their specifications, finally doing away with the "will this cable work" problem. Cables can now be certified and labelled as supporting 240W charging, 40Gbps transfer speeds, and more, and Club 3D is one of the first companies to start using these new cable labels.
Club 3D has lust launched new 240W USB Type-C cables that can be used to deliver 240 watts of power to devices. These cables are available with standard USB 2.0 speeds, USB 3.2x2 speeds (20Gbps), or USB4 speeds (40Gbps). All of these cables are clearly labeled, and more details about each of these cables are available in the press release below.
240W charging is available thanks to the Extended Power Range of new USB chargers and devices, offering 48V voltages at 5 amps. This is enough to charge high performance laptops and other high wattage devices.
Press Release - Club 3D Unveils PD 240W USB Type-C Cables
Club 3D is proud to present to you the next important step in USB-C technology. Less than a year after the official launch of the new USB Type-C Cable and Connector Specification Revision 2.1 and USB Power Delivery Specification 3.1, we can introduce the first 3 cables following the new standards.
The above just means: With our new cables it is possible to charge with up to 240 W, made possible by the Extended Power Range (EPR), which offers now up to 48 V voltage supply at a remaining 5 A. This is a huge step forward and will help users to charge power hungry gaming notebooks and other devices who were suffering from the limitation of 100 W on previous standard.
Here are the products:
- CAC-1573 USB2 Type-C Bi-Directional Cable, Data 480 MB, PD 240 W (48 V/5 A) EPR, M/M 2 m/6.56ft
- CAC-1575 USB4 Gen2x2 Type-C Bi-Directional Cable 4K60Hz, Data 20 Gbps, PD 240 W (48 V/5 A) EPR, M/M 2 m/6.56ft
- CAC-1576 USB4 Gen3 x2 Type-C Bi-Directional Cable 8K60Hz, Data 40 Gbps, PD 240 W (48 V/5 A) EPR, M/M 1 m/3.28ft
All 3 products are already USB IF certified Cables and will be available by next week. For more information please read the detailed news below or click on the item codes above, to be directed to the respective product pages.
Club 3D USB2 Type-C Bi-Directional Cable, Data 480 Mb, PD 240 W (48 V/5 A) EPR, M/M 2 m/6.56ft
The Club 3D CAC-1573 USB2.0 Type-C Bi-Directional Cable, Data 480Mb, PD 240 W (48 V/5 A) EPR, Extended Power Range M/M 2 m/6.56ft connects your Notebook, Tablet or Phone with USB Type-C output to your favorite existing Peripherals, Accessories and Chargers. It enables Data and Power over a single cable and both ways. This cable supports USB2.0 data up to 480 Mbps and up to 240 Watt (48 V/5 A) output for Downstream charging or powering your Notebook, Tablet or Smartphone.
Club 3D USB4 Gen2x2 Type-C Bi-Directional Cable 4K60Hz, Data 20 Gbps, PD 240 W (48 V/5 A) EPR, M/M 2 m/6.56ft
The Club 3D CAC-1575 USB4 Gen2x2 Type-C Bi-Directional Cable, Video up to 4K60Hz, Data 20 Gbps, PD 240 W (48 V/5 A) EPR, Extended Power Range M/M 2 m/6.56ft connects your Notebook, Tablet or Phone with USB4 Type-C output to your favorite existing Peripherals, Accessories and Chargers. It enables Video, Data and Power over a single cable and both ways. This cable supports USB4 Gen2x2 data up to 20 Gbps, Video up to 4K60Hz and up to 240 Watt (48 V/5 A) EPR (Extended Power Range) output for Downstream charging or powering your Notebook, Tablet or Smartphone.
Club 3D USB4 Gen3x2 Type-C Bi-Directional Cable 8K60Hz, Data 40 Gbps, PD 240 W (48 V/5 A) EPR M/M 1 m/3.28ft
The Club 3D CAC-1576 USB4 Gen 3x2 Type-C Bi-Directional Cable 8K60Hz, Data 40 Gbps, PD 240 W (48 V/5 A) EPR M/M 1 m / 3.28ft connects your Notebook, Tablet or Phone with USB4 Type-C output to your favorite existing Peripherals, Accessories and Chargers. It enables Video,Data and Power over a single cable and both ways. This cable supports USB4 Gen 3x2 Type-C Bi-Directional Video 8K60Hz, Data 40 Gbps, PD 240 W (48 V/5 A) EPR M/M 1 m / 3.28ft output for Downstream charging or powering your Notebook, Tablet or Smartphone.
You can join the discussion on Club 3D's new 240W USB Type-C cables on the OC3D Forums.
