Be Quiet reveals their new SFX-L Power series of PSUs
Be Quiet’s mission is obvious, to offer PC builders with silent systems, offering cooling solutions for CPUs, chassis fans and PSUs that are designed to offer quiet operation.
Small form factor PSUs can be particularly troublesome, as their compact design often requires the use of smaller fan designs, which will need to spin at higher RPMs to adequately cool the unit, producing a lot of noise in the process. Be Quiet’s new SFX-L Power series of PSUs manages to fit a larger 120mm fan onto their unit to increase its cooling capabilities, while also offering 80 Gold Levels of efficiency.
These new units will come with modular cables and ship with either 500W or 600W variants, which should be more than adequate for any small form factor system. SFX-L Power series PSUs will also ship with an ATX adapter, which will allow this PSU to be fitted onto an ATX sized chassis when required.
These PSUs will be available with MSRPs of €109 / $119 / £95 for the 500W version and €129 / $145 / £115 for the 600W version.
You can join the discussion on Be Quiet’s new SFX-L Power series of PSUs on the OC3D Forums.
