Cooler Master Announces New V Series Power Supplies
Cooler Master, a leading manufacturer of desktop components and peripherals, today announced the availability of V Series power supplies, the most stable and efficient power supply unit in its class thanks to exclusive 3D circuit design and Silencio FP technology. The V series has fully modular flat cables with energy-saving 80PLUS Gold/Platinum ratings all delivered in a compact design smaller than most Power Supply Units (PSUs) in its class. The V series family is available in V550, V650, V750, V850, V1000 and V1200 watt variants perfect for gamers, enthusiasts and even system builders.
The 3D circuit design does away with unnecessary cables and uses full module boards for cross connection resulting in lower crosstalk and signal noise. This ensures a better power output which also boosts efficiency whereas other PSUs lose efficiency due to cable signal loss. The 3D circuit design also improves heat dissipation in a compact design as there is little heat generated in comparison to traditional cable based designs. Excessive ripple or noise can damage components such as capacitors and cause system degradation. This exclusive design ensures the PSU performs at its best and has minimal interference without signal loss.
Cooler Master Announces New V Series Power Supplies  Cooler Master Announces New V Series Power Supplies
With the implementation of the high-performance Silencio FP fan by Cooler Master, the PSU operates quietly yet efficiently lowering fan RPM by up to 35 % even under 100 % load. 100% Japanese 105C high quality capacitors ensure an extended lifetime delivering excellent performance. Clean, stable voltages lead to less stress on valuable components extending the computer system’s life and reducing instability while gaming or working. The V series come with fully modular flat ribbon cables for easy cable routing using only the cables one needs allowing users to have neater-looking installations and better case airflow.
LLC, DC to DC topology is a technology designed to provide flat, constant output voltage thereby stabilizing the varying voltage. The V series also have received the industry standard 80PLUS Gold and Platinum ratings, a test that compares the quality and efficiency of power supplies in the market. The Gold and Platinum Guarantee rated models come with a 5-year warranty and the V 1200 Platinum comes with a 7-year warranty by Cooler Master.
Pricing & Availability
The V series PSU is expected to be available at local retailers in Europe from today.
You can join the discussion on Cooler Master’s V Series of Power Supplies on the OC3D Forums.
