Genius or Crazy? Thermaltake rethinks PSUs at Computex 2026
Thermaltake’s making PSU upgrades easier with its Dockpower lineup
Thermaltake has had an idea: what if PSUs were easier to upgrade? From that idea has come the Thermaltake DOCKPOWER series, a PSU lineup that allows users to upgrade to higher-wattage units or replace their PSU without disturbing their system’s cable management.
To achieve this, Thermaltake has split its PSUs into two segments: its “Main Unit” and its “Dock”. The main unit is the bit that supplies power, and the dock is the bit that cables connect to. These parts are connected using server-grade 30μ gold-plated contacts, and Thermaltake plans to release more PSU upgrade options in time.
(OC3D’s Thermaltake Booth Tour at Computex 2026)
Thermaltake’s PowerDock PSUs are launching in Q3 and will be available in 750W, 850W, 1000W, and 1200W models. All models will be available in black/white, and will cost $119.99, $129.99, $159.99, and $179.99, respectively. Thermaltake’s initial lineup of Dockpower PSUs is 80+ Gold rated. That said, Thermaltake plans to release more”upgrade options” in the future.
Will this catch on?
Thermaltake seem convinced that this idea has a long-term future. With Thermaltake’s cable hub, the company believes it can make initial cable management easier. It also believes it can encourage PC upgrades that require a PSU change, as users will be able to upgrade without having to redo their system’s cable management.
Honestly, I think most PC upgrades that require a PSU change would also require significant cable management rework. That said, many PC builders hate cable management, so a product that helps them avoid it could have potential.
Honestly, the Darkpower concept feels very marmite. You’ll either love it or hate it. I’m unsure whether to call Thermaltake’s PSU team insane or celebrate their genius. I guess I’ll know when this lineup receives a follow-up or gets axed.
If nothing else, I’m glad to see that somebody’s looking at the PSU market and looking for ways to innovate. While this concept may not be for everyone, it’s hard to argue against this idea’s utility. I also wonder whether any alternative docks could be made available. Is there a market for a cable hub with more of a specific connector? Perhaps a model with many SATA ports for a NAS or server? Could a PSU like this directly interface with a motherboard to power a full system without cables?
You can join the discussion on Thermaltake’s Dockpower series PSUs on the OC3D Forums.
