Lian Li announces two SFX-L Power Supplies
Lian Li has announced two new SFX-L Power Supplies, the 550W PE-550 and the 750W PE-750. Both PSUs share the same external design aesthetic, but the PE-550 comes with an 80+ Gold efficiency rating and the PE-750 comes with an 80+ Platinum Rating.
These new PSUs will come in an SFX-L form factor, making these PSUs 30mm longer than standard SFX PSUs, meaning that they may be too long for certain SFX cases.
The 550W units are primarily designed for systems with a single GPU, with the PSU containing 2x 6+2 pin power connectors, with the 750W unit coming with 4x 6+2 pin PCIe power connections for Multi-GPU setups.
It is great to see more vendors create SFX sized power supply units, hopefully making it much more likely that we will see more cases designed for the SFX PSU form factor in the future.
You can join the discussion on the Lian-Li PE series SFX-L power supplies on the OC3D Forums.
«Prev 1 Next»
09-04-2016, 14:14:22
NeverBackDown
750watts? Impressive! These would be great for a FD Node 202 ITX buildQuote
