Phanteks reveals their REVOLT X series of dual-system power supplies
Phanteks has today announced the creation of the companies first ever power supply units, which will be sold under Revolt X series branding. These PSUs will offer support for up to two systems, enabling the creation of multiple systems inside a single PC case/chassis, offering wattages of 1000W and 1200W at launch.
Seasonic is listed as the OEM of these power supply units, with each PSU offering a custom PCB design for dual-system use, featuring continuous load sharing to provide higher levels of total efficiency than an equivalent hardware setup with two individual power supply units.
Revolt X series power supplies will ship with 80 Platinum Efficiency levels and a 12-year warranty, with Phanteks listing Gaming system/workstation, Workstation/server, Gaming System/Streaming machine and compact multi-user setups (1 enclosure, 2 systems) as potential use cases.
Phantek’s Revolt X series will be fully modular, with individual motherboard and CPU power connectors for each connected system. Covers will be supplied for system 2 power connectors when they are not in use.
Revolt X series power supplies will also feature both standard and hybrid fan modes, allowing the PSU to operate 100% fanless while under 40% load. If the Hybrid option isn’t enabled the fan will run at alow RPM under these conditions.
Phantek’s Revolt series of power supplies will be available starting this September, shipping for prices of $229.99 and $249.99 for the Revolt X 1000W and Revolt X 1200W respectively. More information is available on Phantek’s website.
You can join the discussion on Phantek’s Revolt X dual-system power supplies on the OC3D Forums.
