3D Printer creates LGA115X-compatible mount for clip-on AMD heatsinks
On Thingiverse, a user called xaviervilla wanted to reuse an AMD clip-based heatsink on an Intel LGA 1150 motherboard, moving the cooler from the AMD’s AM3 platform to Intel’s Haswell-series of LGA 1150 CPUs. To do this, xaviervilla created a custom AM3/AM3 to LGA 1150 heatsink adapter kit, which was then printed using ABS and used to mount a Cooler Master Hyper 212 cooler to a previously incompatible socket.
With LGA 1200 and LGA 1151 sockets featuring the same mounting holes as LGA 1150, and AMD’s AM4 socket using the same clip-on mechanism as AM3/AM3, this solution has the potential to be used on modern Intel CPU sockets to offer cross-compatibility with clip-on AMD-compatible heatsinks. This is a great example of how 3D printing can allow old hardware to be recycled into newer systems.
xaviervilla recommends that users of his design print using ABS due to its heat-resistance properties, or PETG for the same reason. PLA is an incredibly popular filament type for FDM 3D printers, but it is prone to warping when heated, making the material far from ideal for a heatsink mounting solution. At this time, we have not tested how widely compatible this solution is with clip-on AMD-compatible coolers. However, we think it would be awesome to see a version of this design make Intel motherboards compatible with AMD’s Wraith Prism CPU cooler.
3D Printer users can look at and download xaviervilla’s LGA1150-AM3 CPU mount adapter on Thingiverse.
You can join the discussion on 3D printers making Intel motherboards compatible with AMD clip-on CPU coolers on the OC3D Forums.
