Atomic Heart’s PC system requirements raised ahead of launch
Atomic Heart will be harder to run than expected
Mundfish has updated the PC system requirements of their Bioshock-like dystopian shooter Atomic Hearts, revealing that PC gamers will need more powerful systems than what was previously communicated by the developers. Both Windows 7 and Windows 8.1 have been dropped as supported OS’ and RAM, CPU, GPU, and storage requirements have increased, signalling that the game is a lot more demanding that previously expected.
Now, Atomic Heart is marketed as a DirectX 12 title, which makes sense given the game’s known support for ray tracing on PC. This is also likely why older OS’ are no longer supported by the game, as the game’s DirectX 11 version has supposedly been dropped. Storage requirements have been raised from 22GB to 90GB, highlighting how much the scope of Atomic Hearts has likely changed over the past few years of development.
CPU-wise, Atomic hearts’ minimum CPU is now AMD’s Ryzen 5 1600 and Intel’s i5-4460. Originally, Atomic Hearts’ recommended CPU was a Ryzen 5 1500X, showcasing how far this game’s PC system requirements have been raised. On the GPU-side, this game’s recommended GPUs were AMD’s RX 580 and Nvidia’s GTX 1060, but now they are Nvidia’s GTX 1080 and AMD’s RX Vega 64. If you plan to enable ray tracing in Atomic Hearts, you will need a much more powerful GPU than what is listed below.
At launch, it has been confirmed that Atomic Heart will support Nvidia’s DLSS 3 technology on PC, which means that the game will support Nvidia Reflex, Nvidia DLSS Super Resolution (DLSS 2), and DLSS Frame Generation (DLSS 3) on day-1. At this time, it is unknown if Atomic Heart will support AMD’s FidelityFX Super Resolution 2 upscaling technology.
Below are Atomic Heart’s old and new PC system requirements.
MINIMUM: (ORIGINAL)
OS: WINDOWS® 7, 8, 8.1, 10 (64-BIT Required)
Processor: Intel Core [email protected] or AMD FX [email protected]
Memory: 6 GB RAM
Graphics: Nvidia GeForce GTX 780 (3 GB) or AMD Radeon R9 290 (4GB)
Storage: 22 GB available space
RECOMMENDED: (ORIGINAL)
Processor: Intel Core [email protected] or Ryzen 5 [email protected]
Memory: 8 GB RAM
Graphics: Nvidia GeForce GTX 1060 (6 GB) or AMD Radeon RX 580 (8GB)
MINIMUM: (NEW)
OS: Windows 10 (20H1 version or newer, 64-bit versions)
Processor: AMD Ryzen 5 1600@ 3. GHz or Intel Core i5-4460 @ 3.1 GHz (AVX, AVX2 and SSE 4.2 support required)
Memory: 8 GB RAM
Graphics: AMD Radeon R9 380 (4 GB) or NVIDIA GeForce GTX 960 (4 GB)
DirectX: Version 12
Storage: 90 GB available space
RECOMMENDED: (NEW)
Processor: AMD Ryzen 7 2700X @ 3.8 GHz or Intel Core i7-7700 @ 3.6 GHz (AVX, AVX2 and SSE 4.2 support required)
Memory: 16 GB RAM
Graphics: AMD RX Vega 64 (8 GB) or NVIDIA GeForce GTX 1080 (8 GB)
DirectX: Version 12
You can join the discussion on Atomic Hearts’ raised PC system requirements on the OC3D Forums.
