Bungie shocks with crazy low PC system requirements for Marathon
Marathon’s coming to PC and consoles on March 5th
Marathon is the newest FPS game from Bungie, the creators of Halo and Destiny, and it’s coming to PC and consoles on March 5th. While the game’s trailers show impressive visuals, Marathon’s PC system requirements are low. In fact, the game’s minimum GPU requirement is a low-end 2016 GPU: Nvidia’s GTX 1050 Ti.
It looks like Marathon will run easily on modern gaming PCs. As a modern PVP shooter, this makes sense. Stable performance is critical for competitive games, and we expect Marathon to target 60 FPS framerates on all console platforms. In fact, I wouldn’t be surprised if there was a 120 FPS mode on higher-end consoles.
Based on Marathon’s PC system requirements, we should expect this game to be well optimised. With the game’s recommended GPU being Nvidia’s RTX 2060 6GB, we can expect all modern gaming GPUs to run Marathon with ease. Note that Bungie has also confirmed that Marathon will use BattlEye anti-cheat, which is a kernek-level anti-cheat system.
Marathon PC system requirements
Below are Marathon’s PC system requirements. While they have no resolution or framerate targets, we’d expect a multiplayer PVP shooter to target 60 FPS framerates.
With these low system requirements, we expect Marathon to run well on modern PCs. This should also be true for Windows-powered gaming handhelds. Right now, we do not expect Marathon to be playable on Valve’s Steam Deck, as its kernel-level anti-cheat may not be compatible with Linux/SteamOS.
Minimum:
OS: Windows 10 64-bit (latest Service Pack)
Processor: Intel Core i5-6600 / AMD Ryzen 5 2600
Memory: 8 GB RAM
Graphics: NVIDIA GeForce GTX 1050 Ti (4 GB) / AMD Radeon RX 5500 XT (4 GB) / Intel Arc A580 (8 GB, with ReBAR on)
DirectX: Version 12
Network: Broadband Internet connection
Recommended:
Processor: Intel Core i5-10400 / AMD Ryzen 5 3500
Memory: 16 GB RAM
Graphics: NVIDIA GeForce GTX 2060 (6 GB) / AMD Radeon RX 5700 XT (8 GB) / Intel Arc A770 (16 GB, with ReBAR on)
DirectX: Version 12
You can join the discussion on Marathon’s PC system requirements on the OC3D Forums.
