Elden Ring Nightreign PC system requirements revealed
Is your PC ready for Elden Ring Nightreign?
From Software has officially released the PC system requirements of Elden Ring Nightreign. These system requirements are higher than Elden Ring’s. However, only the game’s CPU requirements have been raised.
The good news is that most Elden Ring players should be able to play Nightreign without any hardware upgrades. Additionally, it has been confirmed that the game only requires 30GB of storage, which is half what the Storage requirements of Elden Ring are.
Nightreign is coming to PC and consoles on May 30th. The game is an Elden Ring spin-off, not a sequel. Three players can join forces to battle the game’s “Nightlord.” The game takes place over three in-game nights, with the map changing each day. Players must explore the map and combat mighty foes to become stronger, preparing for the upcoming battle with the Nightlord.
(Image from Bandai Namco)
On PC, Nightreign will require the following hardware to run. Higher-end systems will be able to play the game at higher resolutions and framerates.
Minimum
OS – Windows 10 64-bit
CPU – AMD Ryzen 5 5500 or Intel Core i5-10600
RAM – 12GB
GPU – GeForce GTX 1060 or Radeon RX 580
Recommended
OS – Windows 11 64-bit
CPU – AMD Ryzen 5 5600 or Intel Core i5-11500
RAM – 16GB
GPU – GeForce GTX 1070 or Radeon RX Vega 56
You can join the discussion on Elden Ring Nightreign’s PC system requirements on the OC3D Forums.
