IO Interactive release more detailed 007 First Light PC system requirements
007 First Light is coming to PC on May 27th – Here’s what you need to run it
IO Interactive have released more detailed PC system requirements for 007 First Light, which is releasing on Steam and the Epic Games Store later this month on May 27th. These updated PC system requirements add new “Enthusiast” 1440p 60 FPS and 4K 60 FPS system requirements, and add a new “4K Ultra” recommendation for 200+ FPS gameplay.
While 007 First Light will have a unique path tracing mode on PC, it will be released post-launch in “summer 2026”. This means PC gamers will not be able to access this mode on day 1. IO Interactive have also confirmed that the game will support Nvidia DLSS 4.5 on PC. However, they have also failed to confirm if the game will support AMD FSR 4 or Intel XeSS. This game will support both DLSS Super Resolution and Dynamic Multi-Frame Generation on GeForce RTX-powered PCs.
PC Features
On PC, 007 First Light will support an unlocked framerate and in-depth graphical customisation options. The game will also support input remapping. It is currently unknown if First Light will feature a built-in benchmarking utility on PC. IO Interactive’s Hitman games feature built-in benchmarks, and it is likely that First Light will follow this trend.
PC System Requirements
Minimum
- Performance – 1080p at 30 FPS
- Preset – Low
- CPU – Intel Core i5-9500 or AMD ryzen 5 3500
- GPU – Nvidia GeForce GTX 1660 or AMD Radeon RX 5700
- VRAM (Minimum) – 6GB
- Storage – 80GB Minimum / SSD Required
- OS – Windows 10/11 64-bit
Recommended
- Performance – 1080p at 60 FPS
- Preset – Medium
- CPU – Intel Core i5-13500 or AMD Ryzen 5 7600
- GPU – Nvidia GeForce RTX 3060 Ti or AMD Radeon RX 6700 XT
- VRAM (Minimum) – 8GB
Enthusiast 1440p
- Performance – 1440p at 60 FPS
- Preset – High
- GPU – Nvidia GeForce RTX 4070 or AMD Radeon RX 7800 XT
- VRAM (Minimum) – 12GB
Enthusiast 4K
- Performance – 4K at 60 FPS
- Preset – High
- GPU – Nvidia GeForce RTX 4080 or AMD Radeon RX 7900 XTX
- VRAM (Minimum) – 16GB
Ultra 4K
- Performance – 4K 200+ FPS with DLSS 4.5
- Preset – Ultra
- CPU – Intel Core i5-13600K or AMD Ryzen 7 7700X
- GPU – Nvidia GeForce RTX 5080
You can join the discussion on 007 First Light’s updated PC system requirements on the OC3D Forums.
