Is my PC fast enough for Project Cars 3?
Project Cars 3 is due to release on PC on August 28th, which means that PC gamers have less than a month to prepare their systems for the game’s launch on Steam.
On PC, Project Cars 3 will support VR headsets on day-1, including headsets like the Valve Index, HTC Vive and Oculus Rift. To play Project Cars 3 using a VR headset, Slightly Mad Studios requires PC gamers to use Nvidia’s GTX 980 graphics card or better to play the game with stable framerates.
As a whole, Project Cars 3 is designed to run on any PC that can run Project Cars 2, with both games featuring the minimum system requirements. That said, Project Cars 3 contains high-end settings that are designed for modern gaming PCs, which significantly increases the game’s recommended system requirements. On the high-end, Slightly Mad Studios recommends Intel’s i7-8700K or AMD’s Ryzen 7 2700X on the CPU-side, 16GB of system memory and an Nvidia Geforce RTX 2070 or Radeon RX 5700 on the graphics side.
Below are Project Cars 3’s full PC system requirements.
MINIMUM:
OS: Window 10 ( specific versions of 7)
Processor: 3.5 GHz Intel Core i5 3450 or 4.0 GHz AMD FX-8350
Memory: 8 GB RAM
Graphics: GTX 680 or equivalent
DirectX: Version 11
Storage: 50 GB available space
Sound Card: Direct X compatible sound card
Additional Notes: For VR or triple screen use, GTX 980 or equivalent
RECOMMENDED:
OS: Windows 10
Processor: Intel i7 8700k or AMD Ryzen 7 2700K
Memory: 16 GB RAM
Graphics: Nvidia RTX 2070 or AMD RX5700
DirectX: Version 11
Sound Card: DirectX compatible sound card
You can join the discussion on Project Cars 3’s PC system requirements on the OC3D Forums.
