Is your PC ready for Metal Gear Solid Delta: Snake Eater?
Here’s what you need to run Metal Gear Solid Delta: Snake Eater when it launches on August 28th
On Steam, Konami has officially revealed their PC system requirements for Metal Gear Solid Delta: Snake Eater. This highly anticipated remake is coming to PC and consoles on August 28th and will be part of a wave of new titles that use Unreal Engine 5.
Like most new titles, Konami recommends SSD storage when playing their new stealth-action game. The game is said to be around 100GB in size, though this game’s storage requirement may change ahead of release.
CPU-wise, 2025’s new version of Snake Eater requires a CPU with six cores. The game’s minimum CPUs are AMD’s Ryzen 5 3600 and Intel’s i5-8600. The game’s recommended CPUs aren’t much better, with Intel’s i7-8700K and AMD’s Ryzen 5 3600 being recommended. Yes, this game’s minimum and recommended CPUs are the same…
Memory-wise, this game asks for at least 16GB of system memory. Additionally, Konami has confirmed that the game is a DirectX 12 title.
Moving onto graphics, this game’s minimum GPU is an Nvidia RTX 2060 SUPER, and the recommended GPU is an RTX 3080. No AMD or Intel GPU recommendations have been made at this time. Sadly, settings, framerate, and resolution targets are not available for these graphics cards. If Konami has any sense, they will release more detailed system requirements for their game ahead of launch.
Metal Gear Solid Delta: Snake Eater PC System Requirements
Minimum:
OS: Windows 10, Windows 11 (64-bit OS required)
Processor: Intel i5-8600 or AMD Ryzen 5 3600
Memory: 16 GB RAM
Graphics: RTX 2060 Super (8GB)
DirectX: Version 12
Storage: 100 GB available space
Additional Notes: SSD Recommend
Recommended:
Processor: Intel i7-8700K or AMD Ryzen 5 3600
Memory: 16 GB RAM
Graphics: RTX 3080
DirectX: Version 12
You can join the discussion on Metal Gear Solid Delta: Snake Eater’s PC system requirements on the OC3D Forums.
