Nvidia releases high system requirements for Portal with RTX
PC gamers will need a high-end system to play Portal with RTX
Nvidia’s Portal with RTX DLC is launching on December 8th, and it will be free to all owners of Portal on Steam. Portal with RTX revamps Valve’s classic puzzle game with high resolution assets, physically based textures, ray tracing, and DLSS 3. The game is a GeForce RTX showcase that is designed to showcase the power of Nvidia’s latest hardware.
Today, Nvidia has released system requirements for Portal with RTX, revealing exactly how demanding their revamped version of Portal will be. For 1080p 30 FPS gameplay, Nvidia expects gamers to own an RTX 3060 graphics card, and to enable that performance Nvidia expects gamers to enable DLSS. Those are some huge system requirements for 1080p 30 FPS gameplay, and that’s with Nvidia’s DLSS 2 Super Resolution enabled.
For 4K 60 FPS performance, Nvidia’s Portal with RTX requires the performance of an RTX 4080 and the combined capabilities of DLSS Super Resolution (DLSS 2) and DLSS Frame Generation (DLSS 3). If you want to play Portal with RTX at 4K 60, you will need an incredibly powerful (and expensive) gaming systems.
Portal with RTX’s full ray tracing is incredibly demanding, stressing graphics cards to their limits. But with the help of DLSS 2, owners of the GeForce RTX 3060 will be able to achieve playable frames at 1080p at High settings. For a 60 FPS+ 1080p, High settings experience, we recommend the GeForce RTX 3080, accelerated by DLSS 2.
And to enjoy the ultimate Portal with RTX experience at 4K, with Ultra settings, at over 60 FPS, we recommend the GeForce RTX 4080 with the amazing DLSS 3 enabled.
Below are Nvidia’s official system requirements for Portal with RTX. For obvious reasons, Nvidia has not included any non-Nvidia graphics cards within their list of system requirements.
Minimum
Resolution/Framerate: 1080p at 30 FPS
Graphics Preset: High
GPU: RTX 3060 with DLSS 2
Memory: 16GB
OS: 64-bit Windows 10/11
SSD Space: 25GB
Recommended
Resolution/Framerate: 1080p at 60 FPS
GPU: RTX 3080 with DLSS 2
Memory: 16GB
SSD Space: 25GB
Ultra
Resolution/Framerate: 4K at 60 FPS
Graphics Preset: Ultra
GPU: RTX 4080 with DLSS 3
Memory: 32GB
SSD Space: 25GB
You can join the discussion on Nvidia’s system requirements for Portal with RTX on the OC3D Forums.
