Ryzen 3000 Series CPU Specifications Leak
Ryzen 3000 series CPU Specifications Leak
A YouTuber known as AdoredTV has released a variety of specifications for AMD’s upcoming Ryzen 3000 series of processors, revealing impressive specs for both AMD’s low-end and high-end product lineups.
For starters, AdoredTV alleges that AMD will be using the same multi-die technology as their second generation EPYC CPUs, which will allow them to utilise an affordable 14nm I/O die in conjunction with 7nm CPU and GPU cores. This design move will enable AMD to employ the same Zen 2 cores as their upcoming EPYC processors, delivering AMD economies of scale to provide better product bins for consumers and low unit pricing.
On the clock speed front, AMD Ryzen 3000 series processors will boast impressive performance, with their Ryzen 9 3850 boosting all the way up to 5.1GHz, albeit with a 135W TDP. Not bad for a sixteen core processor.
Moving onto APUs, AMD will presumably release Navi/Zen 2 based APUs in Q3 of next year, delivering up to eight CPU cores and up to 20 Navi compute units. Today’s Ryzen+Vega series APUs can be very constrained by memory bandwidth. Hopefully, AMD has worked to help address this limitation with their upcoming designs.
Looking at these leaks, the first thing that comes to mind is how overly optimistic it all sounds, promising a 6-core processor with a 50W TDP and the launch of the majority of the product lineup at CES, not Computex like older rumours have suggested. AMD has stated many times that they are focusing on ROME (7nm/Zen 2 EPYC) for now, making a CES launch window seem too soon for a consumer product reveal.
The promise of 5GHz+ clock speeds in conjunction with the IPC boosts that Zen 2 will offer also come off as being a little too good to be true, though I guess we will have to wait and see if these leaks prove accurate.
CPU Cores/Threads GPU Base/Boost Clock TDP Price Debut
Ryzen 3 3300 6/12 N/A 3.2/4.0GHz 50W $99 CES
Ryzen 3 3300X 6/12 N/A 3.5/4.3GHz 65W $129 CES
Ryzen 3 3300G 6/12 Navi (15 CU) 3.0/3.8GHz 65W $129 Q3 2019
Ryzen 5 3600 8/16 N/A 3.6/4.4GHz 65W $178 CES
Ryzen 5 3600X 8/16 N/A 4.0/4.8GHz 95W $229 CES
Ryzen 5 3600G 8/16 Navi (20 CU) 3.2/4.0GHz 95W $199 Q3 2019
Ryzen 7 3700 12/24 N/A 3.8/4.6GHz 95W $299 CES
Ryzen 7 3700X 12/24 N/A 4.2/5.0GHz 105W $329 CES
Ryzen 9 3800X 16/32 N/A 3.9/4.7GHz 125W $449 CES
Ryzen 9 3850X 16/32 N/A 4.3/5.1GHz 135W $499 May 2019
With Ryzen 3000 series CPUs allegedly shipping with TDPs of up to 135W, it is likely that these processors will be underclocked or will otherwise struggle on older 300-series or 400-series motherboards, despite AMD’s promise to offer forward-compatibility through BIOS updates.
You can join the discussion on AMD’s rumoured Ryzen 3000 series specifications on the OC3D Forums.
