Ubisoft outs high PC system requirements for Assassin’s Creed: Valhalla
Ubisoft outs high PC system requirements for Assassin's Creed: Valhalla
Today, Ubisoft has shown the industry exactly how PC system requirements should be announced, releasing clear resolution and framerate targets alongside a set of clear hardware recommendations.
On PC, Assassin’s Creed Valhalla will be best played with SSD storage, enabling quicker loading times, faster fast travels and a gameplay experience that’s better than playing the game of a mechanical hard did drive (HDD). There’s a reason why “SSD Recommended” is listed within Valhalla’s minimum system requirements.
Should your system feature dual-channel memory, what framerate/setting should I target with my hardware, and what do I need to play the game at a straight 1080p or 1440p 60 FPS framerate. Ubisoft has answered these questions and more. Other PC developers could learn from this, as system requirements for many developers are just hardware recommendations with little to no context.
On PC, Assassin’s Creed Valhalla will feature an unlocked framerate, user-definable framerate limits, resolution scaling options, a built-in benchmarking utility, support for ultrawide and multi-monitor screen configurations and over 120 graphics options for PC gamers to tinker with.
Below are Assassin’s Creed Valhalla’s full PC system requirements, offering 60 FPS options for 1080p and 1440p resolutions. For 4K 60, games will need to use lower settings than the game’s Ultra recommendations and will likely require a higher-end graphics card.
Minimum
Target – 1080p / 30 FPS
Graphics Preset – Low Preset
GPU – AMD R9 380 4GB  / Nvidia Geforce GTX 960 4GB
CPU – AMD Ryzen 3 1200 / Intel i5 4460
RAM – 8 GB (Dual Channel Mode)
OS – Windows 10 (64-bit Only)
Storage – 50GB HDD (SSD Recommended)
Recommended
Graphics Preset – High Preset
GPU – AMD RX 570 8GB  / Nvidia Geforce GTX 1060 6GB
CPU – AMD Ryzen 5 1600 / Intel i7 4790
Storage – 50GB SSD
High
Target – 1080p / 60 FPS
GPU – AMD RX Vega 64  / Nvidia Geforce GTX 1080
CPU – AMD Ryzen 7 1700 / Intel i7 6700
Storage – 50GB SSD
Enthusiast
Target – 1440p / 60 FPS
Graphics Preset – Very High Preset
GPU – AMD RX 5700 XT / Nvidia Geforce RTX 2080 S
CPU – AMD Ryzen 5 3600X / Intel i7 8700K
RAM – 16 GB (Dual Channel Mode)
Storage – 50GB SSD
Ultra
Target – 4K / 30 FPS
Graphics Preset – Ultra High Preset
CPU – AMD Ryzen 7 3700X / Intel i7 9700K
Storage – 50GB SSD
You can join the discussion on Ubisoft’s PC system requirements for Assassin’s Creed Valhalla on the OC3D Forums.
