Ubisoft releases Assassins Creed Origins’ PC system requirements
Ubisoft releases Assassins Creed Origins' PC system requirements
With the release of Assassin’s Creed Origins, it looks like the company is taking PC development seriously, not only offering PC system requirements that are lower than what many expect but also advanced features like Dynamic Resolution rendering, which will downgrade gameplay resolution to maintain higher in-game framerates.
What is the maximum framerate of Assassin’s Creed Origins on PC?
As on other platforms, Assassin’s Creed Origins on PC uses a technology called Dynamic Resolution Rendering that adjusts the resolution on the fly to ensure a framerate as close as possible to the targeted one – in most cases it’s totally invisible for the user. On PC, On PC, players can actually choose what baseline framerate they want to target: 30, 45, or 60 fps. They can also select their maximum framerate between 30, 45, 60, or 90 fps, or decide to completely uncap it.
Is it possible to turn off Dynamic Resolution Rendering?
Yes, by turning off the “Adaptive Quality” option in the menus – this will in fact deactivate Dynamic Resolution Rendering.
Alongside this, Ubisoft will also be offering support for 21:9 resolutions, resolution scale options, an adjustable field of view option and a built-in performance benchmark.
It has been confirmed that Crossfire and SLI will not be available for this game at launch, though it could potentially be added via a future update.
Below are the full PC system requirements for Assassin’s Creed Syndicate, which is said to be a 45GB download at launch, though this does not include the size of the game’s day-1 update.
MINIMUM CONFIGURATION
OS: Windows 7 SP1, Windows 8.1, Windows 10 (64-bit versions only)
PROCESSOR: Intel Core i5-2400s @ 2.5 GHz or AMD FX-6350 @ 3.9 GHz or equivalent
VIDEO CARD: NVIDIA GeForce GTX 660 or AMD R9 270 (2048 MB VRAM with Shader Model 5.0 or better)
SYSTEM RAM: 6GB
Resolution: 720p
Video Preset: Lowest
RECOMMENDED CONFIGURATION
PROCESSOR: Intel Core i7- 3770 @ 3.5 GHz or AMD FX-8350 @ 4.0 GHz
VIDEO CARD: NVIDIA GeForce GTX 760 or AMD R9 280X (3GB VRAM with Shader Model 5.0 or better)
SYSTEM RAM: 8GB
Resolution: 1080p
Video Preset: High
Assassin’s Creed Origins will release on PC on October 27th.
You can join the discussion on Assassin’s Creed Origins’ PC system requirements and features on the OC3D Forums.
SYSTEM RAM: 6GB
Resolution: 720p
SYSTEM RAM: 8GB
Resolution: 1080p
Video Preset: High
