Ubisoft reveals Immortals: Fenyx Rising’s PC system requirements
Ubisoft reveals Immortals: Fenyx Rising's PC system requirements
Immortals: Fenyx Rising is due to launch on PC on December 3rd, launching as a DirectX 11 title with a wide range of PC friendly features. Given the game’s simplistic style when compared to other AAA releases, this game should run well across a wide range of PC configurations, even older systems which are still running Windows 7.
Storage-wise, Immortals: Fenyx Rising will require 28GB of HDD space, with Ubisoft recommending SSD storage in almost all instances. Only gamers who target the game’s minimum requirements should run this game on a mechanical storage drive.
With Fenyx Rising, Ubisoft has promised support for unlocked framerates, lots of customisation options, a built-in benchmarking tool, multi-monitor/ultra-widescreen support and real-time performance analytics tools.
GPU-wise, Fenyx rising will run on GPUs as low-end as Nvidia’s Geforce GTX 660 2GB of AMD’s Radeon R9 280X. However, those who target 1080p 60 FPS at high settings should be using graphics cards like AMD’s RX Vega 56 or Nvidia’s GTX 1070. For optimal performance at high texture settings, GPUs with 8GB of VRAM are recommended and 16GB of dual-channel system memory is also recommended.
Below are the full PC system requirements for Immortals: Fenyx Rising.
You can join the discussion on Immortals: Fenyx Rising on the OC3D Forums.
