Wo Long Fallen Dynasty fixes PC mouse controls and more
Many of Wo Long: Fallen Dynasty’s most glaring issues have been addressed
Like many early 2023 game released, Wo Long: Fallen Dynasty’s PC version launched in a poor state. The game’s keyboard/mouse controls were almost unusably poor, and the game was prone to graphical bugs, flickering, and other issues. Thankfully, things are changing with patch 1.03.
With patch 1.03 for Wo Long Dynasty, the game’s mouse-based camera controls have been improved significantly, and the game’s white flickering issue has been resolved. The release notes for Patch 1.03 also list a long series of “Major Big Fixes”, many of which are PC-specific.
Thanks to the game’s latest patch, Wo Long: Fallen Dynasty now plays much better on PC, with even the game’s PC demo version receiving a patch to improve the game’s mouse-based controls. That said, the game still needs some more polish before it it becomes what we would call a great PC version.
With future updates, Team Ninja has promised to deliver DLSS and XeSS support to Wo Long Fallen Dynasty. Sadly, there is no mention of FidelityFX Super Resolution 2 support for AMD GPU users.
You can join the discussion on Wo Long Dynasty’s first PC patch on the OC3D Forums.
Patch notes – Ver1.03 – 08.03.2023
All Platforms
Adjustments
– Made it possible for guest players in Recruit (online multiplayer) sessions to skip cutscenes and leave the session after boss battles.
Major Bug Fixes
– Fixed a bug in which the player would not be able to progress beyond the area where they encounter Zhao Yun in the main battlefield “Two Chivalrous Heroes” if the saved data from the demo version had a specific progress status and was transferred to the full version.
– Fixed a bug in which the special effects of equipment in the storehouse would be lost if the saved data from the demo version was transferred to the full version.
– Fixed a bug that prevented the player from re-entering the boss area of the main battlefield “Fall of the Corrupted Eunuch” if both the player and Baishe had been defeated at the same time.
– Fixed a bug that prevented the player from obtaining the trophy/achievement “Awakening of the Unscrupulous Hero” during online multiplayer sessions.
Note: After the update is applied, this trophy/achievement can be obtained by clearing any of the main or sub battlefields.
– Fixed a bug that caused a crash when hitting enemies with the attacks “Falling Leaves” and “Scattered Leaves” while using dual halberds that had been decorated.
– Fixed a bug that caused some graphics settings to be reset to the default settings each time the game was launched.
– Fixed some other minor bugs.
Steam/Microsoft Store Versions
Adjustments
Improved the camera controls when using a mouse.
Major Bug Fixes
– Fixed crash-prone situations that occurred in certain environments.
– Fixed white flickers that occurred in certain environments.
– Fixed a bug that caused some resolutions to not be selectable in certain environments.
– Fixed a problem in which the wrong graphics card was selected to run the game in certain environments.
– Fixed a bug that caused a crash when running the game with a certain screen resolution setting, and then applying a specific filter in Photograph mode and exiting.
