Auzentech X-Fi Forte Low Profile 7.1 PCI-E Sound Card
Test Setup and Rightmark Benchmarks
Test Setup
For the Auzentech X-Fi Forte, I used the following PC equipment:
Intel Q6600 @ 3.3GHz
Abit IP35 Pro
8GB OCZ ReaperX PC6400 @ 1000MHz
MSI 8800 GTX
Seagate 7200.10 250GB HDD
Coolermaster Real Power Pro 1000w PSU
Tacima CS929 6 Way Mains Conditioner
Asus Xonar Essence STX
Abit IP35 Pro onboard sound (Realtek ALC888 codec)
To bring out the best in the sound card, I have used the following Audio setup:
Sennheiser HD555 Headphones
Yamaha DSP-AX863SE AV Amplifier
Mordaunt Short 906i Floorstanders (Bi-Amped, silver coated oxygen free copper)
Mordaunt Short 905i Centre Speaker (Bi-wired, silver coated oxygen free copper)
Mordaunt Short 905i Bipole Rears (300 strand oxygen free copper)
Additional Cabling:
IXOS XHD208-300 Toslink Digital Optical Audio Cable
IXOS XHA215-300 2 RCA to 2 RCA Stereo Audio Cable
Well Connected Professional 3.5mm to RCA leads (x3)
I used the fantastic Asus Xonar Essence STX to compare the Auzentech X-Fi Forte to in this review. Whilst the Xonar isn't as versatile as the Forte card, it will provide a benchmark of excellent in stereo sound.
Rightmark
Rightmark is an audio analyser designed for testing the quality of analogue (and digital) paths of audio devices. The results are obtained by playing and recording test signals passed through the tested audio path by means of frequency analysis algorithms. – Rightmark. Note that by using the loop-back tests there may be inconsistencies in the recording and you may get different results when running the tests from home.
Noise Level  Stereo Crosstalk
IMD test  THD Test
The Auzentech X-Fi Forte performs well in our tests with a competent set of results. The slight variances again are due to the testing methodology and in fact turn out fairly similar to the Asus Xonar Essence STX.
There's no doubting that the Forte is a technically excellent sound card. Let's see how the CPU tests fared.
CPU Utilisation
Here we see how much of an impact using the Xonar's software based emulation has on the CPU. Results are again provided by a Rightmark piece of software, this time Rightmark 3D Sound CPU Utilisation test.
(CPU Utilisation set at 16-bit/44.1KHz – 16 buffers)
16-96
(CPU Utilisation set at 16-bit/44.1KHz-128 buffers)
16bit-44KHz
(CPU Utilisation set at 24-bit/96KHz 16-buffers)
24-44
(CPU Utilisation set at 24-bit/96KHz-128buffers)
24-96
The Auzentech X-Fi Forte stayed below an impressive 2.5% CPU utilisation in all tests. It seemed to do even better in the more challenging tests in the suite, not rising above 1.5% CPU utilisation even at 24 bit/96kHz. The X-Fi chips really do seem to take the load of your CPU in scenarios when 3D sound and EAX are utilised.
Altogether an excellent set of tests for the Forte. Now let us move on to how the card does in the 'real world'.
«Prev 1 2 3 4 5 6 7 8 Next»
06-07-2009, 10:52:10
monkey7
DO WANT
At a 75% discount
What about putting PCI-e x1 as good in the conclusion? Most people have too many of those slots anyway and it has more future than the PCI standard.Quote
06-07-2009, 18:19:37
Rastalovich
This sounds like a great card coming from the great review.
I'd have to limit my own conclusion to that of the Auzen Prelude. The card is great, but the Creative software on it is a real pita imo.
If u keep in touch with the Auzen site, they're upd8ing RCx of the drivers time after time. The initial ones ~werent too bad~, the following RC(s) seem to gain in some respects whilst taking away in others - and still u have the freaking Creative control console lurking over everything.
Seeing nothing to suggest otherwize, I'd view this card in the same way, if ur going to set it up to a single or perhaps one additional input, ur likely to do well with it.
Fancy being a bit "creative" - forget it. And I don't think Vista helps. Alchemy also being a bit hit and miss.
For whatever reason they decided to screw up the sound options that the pc had when going from xp->vista, even tho the theory in the vista control is a good idea imo, I would love them to try and get it mostly correct in Windows 7.
Let's pretty much hope that Creative born examples continue to work fine and without hackage in Windows 7 - they "should".
Great review. I do have reservations tho, especially when paying £122!Quote
06-07-2009, 18:20:35
FarFarAway
PCI-e is becoming the standard nowaday, so whilst it is a plus - it's not a huge plus over the competitionQuote
11-07-2009, 09:16:48
Rastalovich
Just an FYI I got in the mail, sorry about the layout:
7.10.2009
X-Fi Forte Driver for Windows 7
Auzentech Releases X-Fi Forte 7.1 Multi-Driver for Windows 7, XP, and Vista
Santa Clara, CA: Auzentech, Inc (www.auzentech.com) announced today the immediate availability of the Multi-Driver for the X-Fi™ Forte 7.1 sound card. The multi-Driver is compatible with Windows® 7, XP, and Vista 32-bit and 64-bit operating systems.
The new driver must be a fresh install on a 32-bit or 64-bit edition of Windows® 7, XP or Vista. For details and downloads, visit the driver download page.
Download Driver:
http://www.auzentech.com/site/download/updates.php#xfiforte
Product Page:
http://www.auzentech.com/site/products/x-fi_forte.php
About X-Fi™ Forte
Officially released on January 19, 2009, the Auzen X-Fi™ Forte 7.1 is the first Low Profile native PCI Express® audio card that Auzentech has designed especially for gamers and audiophiles. Compared to the X-Fi™ chipset reference design, the Auzen X-Fi™ Forte 7.1 has improved circuitry and components. The Auzen X-Fi™ Forte 7.1 marks the first time the Creative X-Fi™ Native PCI Express® chipset has been available in a low-profile board, as well as the first time it has been available in a a third-party soundcard. X-Fi™ Forte ships with Dolby™ Digital Live. DTS Connect™ will be available as a driver download for Windows Vista®.
About Auzentech, Inc.
AUZENTECH, Inc. is a provider of quality consumer electronics products, which is headquartered in Santa Clara, CA. AUZENTECH developed the World's first Dolby Digital Live Sound card (X-Mystique 7.1 Gold) and the World's first DTS Connect Sound Card (X-Plosion 7.1 DTS Connect) and continues to bring the most innovative audio products to the market.
Contact:
[email protected]Quote
22-09-2009, 19:39:12
MadErn
I just purchased one of these card and will receive it in a couple of days....
The reason I am curious about the mic boost is I have Vista 64 bit OS and have a Creative X-Fi Titanium Fatal1ty Sound Blaster Pro 7.1ch Gaming Official PCI Express Sound Card in it at the moment and There is no mic boost!!! Card sounds great, it's just a shame my team mates can not hear me... They can hear me but the volume is to low during game play.
I tried everything I can think of and then went to Creative forums to find out creative did not add a mic boost to this cards software for Vista!!!
Well thought I would check here to see if anyone has a problem not being heard with this card during gameing with their mates.Quote
