Roccat Khan Pro Headset Review
Up Close
Roccat Kahn Pro Headset Review
Up Close
The Roccat packaging has always had an attractive simplicity to it and the Khan Pro is no exception. Large product image. Clearly highlighted features. Simple logo. Bosh, done.
The Khan Pro continues Roccat's excellent design with bold logos on the outside of the ear pieces and hinges that are fully flexible to ensure maximum comfort. The cable is long and there is an included two-into-one combiner to ensure maximum compatibility. The microphone is rigid but that should at least ensure that anyone using it wont be shouting into your ears like most people we come across in our online gaming exploits, whilst you can yell at them without fearing your voice clipping out.
The ear coverings give away the price point of the Khan Pro, being that thin pleather style that nearly always wears out in a hurry. We'd much rather Roccat have gone with foam coverings for this very reason, or bumped the price up by a tenner and gone full leather. However there is plenty of room for even the largest ears, so if you happen to be a friend of Noddy then you'll be okay.
Rather than go down the common route of having an inline remote to control the volume and microphone muting, the Khan Pro mutes the microphone when you lift it to the vertical position, allowing Roccat to move the volume dial to the side of the headset. It's easily accessible and not having a remote in the cable helps neaten things up. No matter where companies put the remote it's always either too near your head or somewhere by your thighs.
Although the primary material for the Khan Pro is plastic to help keep the weight down, the hinges are sturdy and the headband is flexible steel. This should ensure that, whilst the headset is light, that lightness isn't a quality compromise.
«Prev 1 2 3 Next»
22-12-2017, 18:18:39
ImprovizoR
Gaming headsets are generally not very good for the money. People should really stop buying this crap tech. It's far better to get a decent pair of headphones and a separate microphone if you truly need it.Quote
22-12-2017, 20:52:13
Wraith
While I agree with the end of your statement and would now always recommend dedicated Cans, Mic and even a DAC.. not everyone has, lets ball park a £210 budget on audio equipment. Gaming headsets have their place in the market they are reasonably priced and have I must say improved a lot over the last few years.Quote
23-12-2017, 07:41:21
ImprovizoR
Sure. But pretty much all Hi-Fi Stereo headphones in the same price range as gaming headsets have a ridiculous advantage over gaming headsets in terms of audio quality. For example, if you want to spend $100 on a headset, headphones in that price range would give you a better bang for your buck. Hell, some $50 headphones like the ones from Superlux are much better than some $100-$200 gaming headsets. Not better than all of them, but better than quite a lot. And that's even without any other audio equipment.Quote
23-12-2017, 08:30:53
looz
But a decent microphone is like 40€ minimum.
By decent I mean USB one since on-board microphone jacks are a mixed bag.Quote
23-12-2017, 14:43:11
NeverBackDown
You can get a cheap clip on mic for like $10Quote
