Steelseries Headsets
Test Setup and Specifications
Testing Hardware and Specifications
Testing Hardware
Motherboard : ASUS Rampage Formula
RAM : 4gb Corsair Dominator 1066
GFX : ATI HD4870
Soundcard : ASUS Xonar
PSU : Corsair HX1000
HD : Western Digital 320GB
CPU : Intel Q6600
OS : Windows 7 Ultimate
Specifications
As with all our tests, specifications have been taken directly from the manufacturers website. The main thing of note is that the microphone on the 5H v2 USB and the Siberia Neckband appear to be identical, and the specifications bear this out. The Siberia In-Ear microphone has identical specifications too, so hopefully they all provide the same performance.
SteelSeries 5H v2 USB:
Headphones
- Frequency response: 16 - 28.000 Hz
- Impedance: 40 Ohm
- [email protected] 1kHz, 1 Vrms: 110 dB
- Cable length: 1,0 + 2,0 = 3,0 m (9,8 ft.)
- Connectors: 3,5 mm
Microphone
- Frequency response: 75 - 16.000 Hz
- Impedance: 2K Ohm
- Pick up pattern: Uni-directional
- Sensitivity: -38 dB
Soundcard
- USB: 2.0
- Surround sound: Virtual 7.1
- Equalizer: 12 channels
- Jack: 2 x 3,5 mm (USB cable included)
- Operating systems: Win XP/Vista/Win 2000/Win 98/Win ME
Siberia Neckband:
Headphone
- Frequency response: 18 - 28.000 Hz
- Impedance: 40 Ohm
- [email protected], 1V rms: 104 dB
- Cable length: 1,2 m + 1,5 m = 2,7 m / 8,9 ft.
- Jack: 3,5 mm (6,3 mm converter included)
Microphone
- Frequency response: 80 - 15.000 Hz
- Impedance: 2K Ohm
- Pick-up pattern: Uni-directional
- Sensitivity (1V/[email protected] kHz): -38 dB
Siberia in-ear headset:
Headphone
- Frequency response: 30 - 24.000 Hz
- Impedance: 16 Ohm
- [email protected], 1V rms: 90 dB
- Cable length: 1.0 m + 1.8 m = 2.8 m / 9 ft.
- Jack: 3.5 mm
Microphone
- Impedance: 2K Ohm
Phew. That's a lot of data to take in so I hope you were keeping up at home. Finally we're going to test these and see if the performance is as good as their looks.
«Prev 1 2 3 4 5 6 Next»
09-01-2010, 07:03:06
splinter
the in-ear headset should get a higher score than the other 2 headsets imo, kickass noise reduction perfect for lan eventsQuote
10-01-2010, 08:48:49
Apans
Great review tho i missed "SteelSeries Siberia v2" in the test.. one of there most famous serie for gamers...
but anyways thanks for reviewQuote
10-01-2010, 09:12:31
tinytomlogan
Those were the headsets steel series asked to be reviewed, have got more planned for a later date though Quote
10-01-2010, 09:41:29
killablade
Nice review! Looking forward to a review of the Siberia v2Quote
10-01-2010, 19:41:58
Apans
Cheers
looknig forward to it m8!Quote
