Steelseries Siberia 840 Wireless Headset Review
Control
Control
If we showed you all the settings that the box has in its submenus this review would be about twenty pages long, You can change the volume on a per-input basis, adjust which input you're using, apply Dolby, fiddle with equalisers, check the charge status of the battery in the charging port as well as the headset itself. In short if you want to be able to change something then the OLED transmitter box enables you to do so, and only in very complex scenarios - creating your own equaliser profile for example - would you need to resort to using the Steelseries Engine software. It's a fantastic piece of kit that really looks classy and can quickly get you to the input you wish to use, should you need to move between them regularly.
«Prev 1 2 3 4 Next»
14-11-2016, 23:47:09
Firedrops
Do you guys have any quantitative tests for audio latency?Quote
21-11-2016, 10:08:46
__iggy
premium??? using mini usb wtf is it 2009??? and that re-branded nokia phone battery from some dead stock china factory klkkkkkkQuote
11-12-2016, 05:01:32
dimiav
what are you talking about? the USB connects the transmitter to PC... the mini USB is on the transmitter side...
the Batteries are excellent Lithium-ion battery... something that every wireless product should use today...
they also give you an extra battery that always being charged for fast swap.
so yes, it is PremiumQuote
